Pred: I was expecting a higher terminals speed than 95mph from your car. What was your highest MPH that night? The helmet dose block out a lot of noise you need. Particularly when shifting close to the rev limit. I hit my rev limiter numerous times in 1st and 2nd.
Jet: Scared you'll run a 15, huh? :)
  • Replies 92
yeh heaps mate, how could my car go slower when the track had 3x more traction last nite, itd only run a 16 if u drove cos im tippin u have no idea...my car will run mid 13s easy...with wheelspin in 1st and 2nd, i had a t/s of 101, and my car has more power that preds, if i had the same mods as him (fmic, ebc, coil overs and pineapples), well, u can figure out 4 yaself what times id b runnin..
so u can take ya piece of crap, tank, ugly box peice of shite and drive it back to where ever it is u cam from in ya mummas ug boots :)
haha, just read u live in camberra, OMG, haha, enuff said
no wonder u have a gay car and are a bit of a tool
do every1 a favour a shoot yaself or take yaself to a gtir forum
i thinks its www.ifyouratoolanddriveamegauglycar.com.au :shake:
by the way its a joke dude so dont cry, il send u some tissues if you would like?
damn i'm jealous! 12.3!!! congrats. what kind of tyres you got at what pressure and what what were your take offs like? (rpm, dump, slip, etc). all i could manage on my run was a terminal of 107mph as well at 12.7 what were your 60 foot times? mine were about the 1.8sec mark.
Originally posted by JAGR33
Anyway after a few crappy runs, the best time achieved was 12.3 @ 107mph. Quite happy with that considering the mods I've got (full exhaust, pod filters, adj cam gears and 12psi boost). Clutch was slipping like f**k on the last run so nismo twin plate is going in next week.
Pity we didn't get to see more of you guys out there having a bit of fun....
Yeah Ula32, didn't expect to be that quick. Tyres are Bridgestone G'Grids 265/35/18 (all round), not sure what psi they had in them???
Take offs were a bit inconsistent, especially the last two runs, the (standard) clutch was slipping quite a bit. Found that launching it at 5500 rpm was the best, as the start line was very grippy. Also perfect conditions for drag racing.....
60 ft time was 1.850, 660 ft was 7.963 @ 88.44mph and ET 12.391 @ 107.53mph. Haven't got a scanner to post time slip...
U got similar mods yeh???
Ula: The 0-60 foot wouldn't matter so much. Especially since you're both 4WD. Compare the half-track times and speeds. Perhaps his power in lower gears and torque curve is more aggressive.
JagR33: I still think the best way to launch the GTR would be to get the rear wheels spinning as soon as possible. This will engauge the 4WD sooner and will hook-up a lot earlier.
Just for comparisons sake. Richie (SXYGTR) did a 12.9 when I ran my car two years ago at 106mph. His car was 'stock-as-a-rock'. He can confirm that though. He was launching at the rev-limiter, so he told me.
poyz - My car ran a 13.1 when I first got it (completely standard) but it was in 30 degree heat, not ideal drag conditions.
As far as launcing on the rev limiter, this causes too much wheelspin even though its 4wd, and slightly reduces the time. I know coz I've tried it. You have to find the right amount of revs where its enough to sling shot off the line and not bog down. Depending on the grip of the start line, I found that between 5500 and 6000 rpm was as good as perfect on the night.
Another major factor why its not good to launch it on the limiter is that the standard clutch is not really up for it. Several launche like these results in a new clutch.
With a good twin plate clutch and some drag slicks, then yes you could probably launch it on the limiter....
mods are almost similar... the only differences is that i dont have front pipes and cat to suit, i'm running 2 psi more and i had a new clutch in there for about 2 months. my tyres could play a part, they're only cheapie $120 tyres all round. tuning could play a part too. i got it setup more for top end than torque. maybe i need to find more torque. my 660ft was 8.156 @ 85.87mph so i'm slower there already.
maybe tuning i guess.... launching at 7grand for me i found that it was way better... whatever you do, don't launch at 3 grand... lol :(
pa... i don't think i saw any turbos ran under 10 that night but i was kinda busy... mostly all the old aussie cars all stoopided up with supercharges and things who spend so much money on them, but half the time they'd be nowhere near street driveable.
If I had a 12 second street car (even if its 12.9) that i could drive each day i would be happy.. even if its only a GTS-T i would still be happy. I'm happy knowing that its maybe only $5k away if I want to do it one day.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
