I hope someone can help me here.
My boss (runs a dealership) once bought a R34 GTR in yellow and sold it [cheap] a couple of weeks later to make a quick profit. The guy that bought it knew his shit and the day before he picked the car up asked for the VIN. So he paid for the car, hopped in it and told my boss that it was was 1 of 3 in Australia. It was completely worked from the factory (apparently had a roll cage built in, but covered up by carpet and pillar covers??) Not knowing my boss was kicking himself afterwards lol.
I would supply a VIN no. and pics if i could find them but i don't at the moment. They were apparently built by nissan to compete in racing then they cancelled it. I know this information is kind of pathetic but I thought it was worth a try.
Could it possibly be an N1?
What kind of R34 GTR's were produced in such limited numbers, other then the ones listed?
If you can get a VIN, it should quickly clear it up.
Could be one of a few things though
1. N1's came in white, however this is due to teams quickly painting them in there own colours
2. could be a run of the mill GTR prepped by NISMO for a one make series - haven't heard of one, but not a far stretch
3. Could be something limited like an N1, R1, Z-tune (unlikely) etc which was bought and the retro fitted with the stuff you mentioned
Either way, sounds nice and rare or not, find those pics :-)
Sounds more like the bloke buying it was making up bullshit. I had a bloke telling me his old man bought a WRX from the dealership in Bathurst, but when they built it in Japan they had accidently used a WRC shell, so it was heaps lighter, but a made a few odd creaks etc when the body would normally flex because it was heaps stronger... A roll cage hidden behind the trim and carpet... You ever tried fitting a 1.5 inch diameter pipe between trim and the body? or making it impossible to see to the point a car dealer would not charge extra for it?
P.S., not having a go at RB27DETT, just the guy buying the car who was stretching the truth
I currently own a 32 Gtr V-Spec II in a late 93 platform. One of only 1300 or so made from memory so some what rare :D At the moment its pretty standard with only minor mods such as turbo back exhaust, alarm, rims, turbo timer, hicas lock out and thats about it from memory. Next week but that will be a bit different ha ha :P still too long away lol for pictures just click on my profile got a few on there
cheers
As a Moderator, I need to advise you that no p@rn will be tolerated. :(
This one is my new Rare Skyline. They don't get much rarer than this little beauty
Pic taken at Phillip Island Historics this last weekend.
  • 3 weeks later...
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
