there was 1 for sale on ebay last year but it was resprayed which turned me off - he had problems selling the car at the time.
gun metal resprayed white.
this was bretts gtr which i saw about 6-7 years ago in his garage but then sold it, nice example:
http://www.skylinesaustralia.com/forums/topic/201368-ultra-rare-r32-v-spec-n1-for-sale/
Yes, a 92 N1. One of the 228 built. I have all paperwork, owners manual and every shaken (like rwc) from day one. Seems stock engine wise other than pod filters, exhaust and a few bolt on suspension goodies. Has had a/c fitted and a radio. Also have all the stock parts to return to standard.
lets see some pics :) i was unaware you owned an n1
Awesome and congrats.
Seems most have had air and radio fitted. So far have only seen 1 without AC
Do you have the stock non AC air controller? Pretty hard to find but i do know that Nissan have them on the shelf for a nice little fee, if you ever thought about removing the AC
and def +1 for pics!!
Ill get some pics up. Its been a recent addition thats for sure, and a nail biting wait on what seemed like the slowest boat from Japan! The only thing im not taking out is the AC, I live in QLD!! Will chase up a fan controller, always amazed at what Nissan still have in stock for these cars. It has the unusual split condensor and oil cooler which I assume is factory? It all fits in the same spot as the standard cars' condensor core. Ive only ever seen it on one other car.
  • 1 month later...
Thanks for your comments blk180, Marko and Kim.
Nothing more than cosmetic stuff to be done to this.
My wife catches me going into the garage to take a peek at this.
Pretty clean inside.
ECU by Mine's needs to be switched and adapted for 98RON - I was given a PFC as a present from the former owner of Matthew's VS2 Nur
And thanks to Kristian for the past two R34 GT-Rs, I'm a lucky guy. :thumbsup:
Yeah no aircon (just a blank switch) and a blocking panel where the stereo goes, although mine had the stereo optioned back in - only a single DIN radio (CD player not functioning!) with the two front speakers.
The N1 stickers were a factory option, so rare that I'd never seen them before until Terry unearthed them!
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
