Hey Yall
Is there a way of telling a BNR32 Vspec 1 to a Vspec 2 by the engine tags. Have been told that a Vspec 2 on a 32 will be something like this BNR32XXX-XXX8......if there is no 8, it is a Vspec1. If someone can confirm this it would be great.
Cheers
Nearly.........
The 11th digit on the blue Nissan Build Plate on the firewall needs to be an 8.
A std GT-R will have a 7 and a V-Spec 1 will have a blank space with no number inserted.
Cheers,
Bob.
Dont know if my car counts as rare, its a normal R34 GTR but in a pretty rare colour....
Would be very interested in knowing the amount of Yellow BNR34s made, or the amount in Aus... wouldnt imagine there would be too many?
1331573428[/url]' post='6271895']
Nearly.........
Cheers,
Bob.
Thanks bob. There seems to be a vspec1 in Vic getting sold as a vspec2..... Just had to be sure.
Cheers
Cheers
u should contact the seller and if he denies the truth i'd be circulating the advert on this thread...in the best interest of other potential buyers
  • 3 weeks later...
Yes there is one here in Vic, user name YLWGTR with carbon fiber tail lights. A monster.
^Thanks guys, im guessing that there is probably around 10 or less in aus given the 3 above including mine, there is one in wa for sale on carsales, and other random ones i have seen/heard about.. pretty rare then i guess... still would love to know how many were made, but im guessing it would be impossible to find out.
Cheers
In R34 GTRs, yellow and red are both rare colours as they were only available for about 18 months - those colours were dropped when the series 2s came out.
Yea that is what i thought... but i dont believe they were made on a 'limited run' basis? as the MNPs were etc i believe?..
Im guessing they were made to order?.. so a number will be pretty hard too come by...
Would love to see some red ones in Aus also.... Would think they would be a rarer colour again.
On the topic of 34GTR's, has anyone here heard of the single midnight purple Z-tune produced by Nismo from factory?? The car was sold not long ago with less than 3,000kms on the clock. Considering a Z-tune in silver fetched around $250,000 new (or so I heard) I wonder how much this beast fetched?
IMO this has got to be one of the rarest, if not the rarest GTR produced as of yet...
Does anyone have a clue as to how many BNR34 GTR V Spec II Nur's are 'live and kicking' around the world these days?
Or let alone the total registered here in Oz?
I know of 4 in WA - this is my example ( which is currently FOR SALE here - http://www.skylinesaustralia.com/forums/topic/398073-fs-perth-2002-nissan-skyline-bnr34-gtr-v-spec-ii-nur/ )
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
