R34 GTR M SPEC (only 228 ever built) rarer then the M SPEC NUR (250 BUILT)
And not so rare R33 V SPEC (6,551 built) so I guess the Nitto 2.7 makes it rarer...lol
Actually Justin, I have a Nissan R34 GT-R M-Spec Brochure :)
  • 1 month later...
17 years of importing /owning skylines.. must be more than 70 by now and a 260rs for the pram days this one is fast becoming the favourite.
http://s839.photobucket.com/user/jake32spar/library/gtr%204door?page=1
Edited by jake32
  • Like 1
  • 1 month later...
Lucky I just picked up a rs260 then :) Edited by poohkies
  • 3 weeks later...
  • 3 months later...
Bobby's (NISMO's) car as well as mine, in their glory!
'Tis worth mentioning that both of these N1s left Japan without the Japanese knowing that they were indeed N1s
VIN/Chassis No. won't necessarily tell you that they are N1s but...
On the Build Plate, on Line #4, there is a code of alphanumeric symbols that detail what the car has (or doesn't have) as it leaves the Nissan factory.
So why not ask your friendly importer to try and locate one for you - even if it takes ages?
  • Like 1
  • 4 weeks later...
Hehehe, I knew ;)
One day we'll get our cars together for a shoot Terry. One day.
1990 GTR Nismo Group A #399, Auckland NZ. All original aside from a Nismo exhaust system and Nismo damper-adjustable suspension, paintwork is at least 95% original and gleams like it just left the factory. I finally own one of my dream cars. Next.. a 400R :-)
  • 4 months later...
Here's a standard R34 GTR with a different kit on it. It's the history that is the real kicker. It was owned by the late Paul Walker. This is one of the three GTR's he owned. Rolled up to the shop this morning looking for paint touch up. Guy plans on putting it thru the Barret Jackson Auction coming up in Las Vegas, Nevada this year. Extremely clean with legit documents confirming vehicles history. post-116132-13951734784264_thumb.jpgpost-116132-13951734943885_thumb.jpgpost-116132-1395173508596_thumb.jpg
Here's a standard R34 GTR with a different kit on it. It's the history that is the real kicker. It was owned by the late Paul Walker. This is one of the three GTR's he owned. Rolled up to the shop this morning looking for paint touch up. Guy plans on putting it thru the Barret Jackson Auction coming up in Las Vegas, Nevada this year. Extremely clean with legit documents confirming vehicles history. attachicon.gifImageUploadedBySAU Community1395173477.529368.jpgattachicon.gifImageUploadedBySAU Community1395173494.211226.jpgattachicon.gifImageUploadedBySAU Community1395173505.311136.jpg
Gallow 12 or Gallow 24?
:rofl:
Jokes aside, it's a R34 GT / GTT.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
