Hi,
I started this thread back then when I had a N1 R32 GT-R and there was little information on rare Skylines.
This thread has largely been replaced by:
http://www.gtr-registry.com
That site has everything you'd ever want to know about Skylines.
This sounds interesting. Got pictures?
Heres a few original pics of the car on stock R34 rims.
Build Date: 11/1997
ECR33-133971
1997 Series 2.5 R33 GTST Turbo Coupe Automatic
LP2 Midnight Purple
Originally registered here with 96,400kms, currently has 99,000kms now approx.
Zero modifications upon arrival. Only mods to date are updated 18" rims.
  • 1 year later...
On 11/3/2017 at 1:59 PM, glenndrayton said:
Hi,
SAU FTW.
  • 1 year later...
  • 1 year later...
That is an unusual spec, if you post the VIN we can double check the original spec in FAST. I've never come across a 33 gtst without HICAS or stereo before. All 33 gtst were designated Type M though.
  • Like 1
7 minutes ago, sin- said:
Is it a ER33? There is also GTS25T Type G. If so there was 22 produced without passenger airbag and with the no audio option.
Yeah bro, we can all read the GTR registry, but its all speculation until he posts the VIN.
It came with hicas, passenger airbag and no sterio just to fix that mistake up.
9 hours ago, JasonMate said:
Iv got a 1996 R33 gts25t series 2 type m that was released off the factory without a stereo, front passenger airbag and hicas. Duno if that's rare i cant find good info on it.
So its a standard R33 gtst, not rare and you learned how to use GTR.registry, so not quite a total waste of oxygen.
Where does this r33 fit in? its a mirror image.
https://en.wheelsage.org/nissan/skyline/r33/44527/pictures/516592
Sorry if this is all stupid questions for this thread but i cant find answers.
Makes sense the dealer fitting different stereo, I didn't think about that.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
