R34 GTR M SPEC (only 228 ever built) rarer then the M SPEC NUR (250 BUILT)
And not so rare R33 V SPEC (6,551 built) so I guess the Nitto 2.7 makes it rarer...lol
Actually Justin, I have a Nissan R34 GT-R M-Spec Brochure :)
  • 1 month later...
17 years of importing /owning skylines.. must be more than 70 by now and a 260rs for the pram days this one is fast becoming the favourite.
http://s839.photobucket.com/user/jake32spar/library/gtr%204door?page=1
Edited by jake32
  • Like 1
  • 1 month later...
Lucky I just picked up a rs260 then :) Edited by poohkies
  • 3 weeks later...
  • 3 months later...
Bobby's (NISMO's) car as well as mine, in their glory!
'Tis worth mentioning that both of these N1s left Japan without the Japanese knowing that they were indeed N1s
VIN/Chassis No. won't necessarily tell you that they are N1s but...
On the Build Plate, on Line #4, there is a code of alphanumeric symbols that detail what the car has (or doesn't have) as it leaves the Nissan factory.
So why not ask your friendly importer to try and locate one for you - even if it takes ages?
  • Like 1
  • 4 weeks later...
Hehehe, I knew ;)
One day we'll get our cars together for a shoot Terry. One day.
1990 GTR Nismo Group A #399, Auckland NZ. All original aside from a Nismo exhaust system and Nismo damper-adjustable suspension, paintwork is at least 95% original and gleams like it just left the factory. I finally own one of my dream cars. Next.. a 400R :-)
  • 4 months later...
Here's a standard R34 GTR with a different kit on it. It's the history that is the real kicker. It was owned by the late Paul Walker. This is one of the three GTR's he owned. Rolled up to the shop this morning looking for paint touch up. Guy plans on putting it thru the Barret Jackson Auction coming up in Las Vegas, Nevada this year. Extremely clean with legit documents confirming vehicles history. post-116132-13951734784264_thumb.jpgpost-116132-13951734943885_thumb.jpgpost-116132-1395173508596_thumb.jpg
Here's a standard R34 GTR with a different kit on it. It's the history that is the real kicker. It was owned by the late Paul Walker. This is one of the three GTR's he owned. Rolled up to the shop this morning looking for paint touch up. Guy plans on putting it thru the Barret Jackson Auction coming up in Las Vegas, Nevada this year. Extremely clean with legit documents confirming vehicles history. attachicon.gifImageUploadedBySAU Community1395173477.529368.jpgattachicon.gifImageUploadedBySAU Community1395173494.211226.jpgattachicon.gifImageUploadedBySAU Community1395173505.311136.jpg
Gallow 12 or Gallow 24?
:rofl:
Jokes aside, it's a R34 GT / GTT.
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
