hi everyone i just recieved pictures of the r34 im importing
its a 4 door gtt manual turbo but in the picture it looks like i have an auto steering wheel.. can anyone confirm it is true or is this for stereo control? also in the picture it looks like there is a fold out tv or cup holder or something can anyone confirm this? its just above the tape deck (sorry pics arent that clear)
ive fax the supplier my questions but i thought id ask here as well
Edited by sskylinee
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/
Either manual conversion or they whacked on a auto steering wheel (maybe the airbag blew and they had to replace the steering wheel)
The buttons you see are the tiptronic buttons I believe.
What does the dash look like? does it show the gears in the middle? if so the car was probably a manual conversion.
Above the tape deck, maybe a CD player? pretty sure its not a TV
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2361914
thanks 4 the replies guys..
i dont actually have any other pics that could help
i havent got the vin number yet but ill have to ask the supplier 4 it.. the buyer in japan is always at the auctions and takes a while to reply
the thing above the tape deck doesnt look like a cd player at all.. fingers crossed its a tv but knowing my luck its probably not :D
i have noticed that normally the tape deck is under the climate control and theres a spare din underneath..
but mine isnt..
ive attached another pic
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2363511
so manual 4 doors are rare? so my concern now is whether i got an r34 manual gearbox or could it be r32 or r33?? anyway of checking? do they even fit?
r33 gb and r34 are different right? ratio etc?
thought id add a pic of the whole car (show off) :)
shes stock to the bone so i hope i wont have to many problems with compliancing
thanks again 4 the help guys
Edited by sskylinee
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364073
Main difference is r34's are push type clutch and 33's series one and before a pull type (or vice versa) I personally wouldn't be too worried if it's been done well.
Do you mind telling us what you paid for it?
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364122
if the conversion was done in japan, then you can rest assure it was most likely done properly, no need to stress too much. The only thing of concern is when you import a car like this that has been converted, the auction papers or your broker should have stated this fact.
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364281
how long is a while?
it took almost 6 months of looking before I got my manual GT-V sedan.
if you had a full pic of the dash we would be able to see which dash cluster you have because if it was originally a Tiptronic and they've left the tiptronic wheel in place maybe they've left the auto dash cluster in place as well.
if you have a copy of the auction report the VIN will be on it.
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364546
  • 1 month later...
the thing above the tape deck doesnt look like a cd player at all.. fingers crossed its a tv but knowing my luck its probably not :(
but mine isnt..
Hi,
That is a tv that is connected to the navigation system located at your boot.
I slo have this in my R33 Series 2.
Im guessing its a factory option.
I was wondering if anyone has been able to either use the factory navigation system in AU?
Also I wanted to know if the tv can be hooked up to a dvd player?
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2477812
  • 1 year later...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
