http://www.autoblog.com/2005/11/27/next-91...rbine-geometry/
http://digg.com/tech_news/Porsche_s_new_tu...ogy_for_the_911
Next 911 Turbo to feature Variable Turbine Geometry
November 16 of this year marked the day a century ago that Dr. Alfred Buchi received the first patent for an exhaust gas turbocharger. Porsche will be celebrating the turbo's 100-year anniversary a little late when it introduces the next 911 Turbo sometime next year with Variable Turbine Geometry. This technology allows the angle of the compressor's turbine blades to continually adjust. While some diesel engines have enjoyed this technology since the Nineties, the higher exhaust gas temperatures created by gasoline engines necessitated the creation of new heat-resistant materials to handle the hotness. Porsche and Borg Warner Turbo Systems were able to overcome the heat issue and have developed a VTG turbo system that will be incorporated into the next 911 Turbo. The VTG turbo will allow Porsche's flat-six to mimic a twin-turbo setup with a much broader torque curve and more flexible powerband than a standard single turbo could provide on its own. Power ratings for the new VTG turbo engine haven't been released and probably won't be until the new 911 Turbo surfaces sometime next year.
I'd love to see a working diagram of one of these turbos in more detail.
https://www.sau.com.au/forums/topic/127801-variable-turbine-geometry/
Your wish is my command.
http://www.porsche.com/all/masterwerk/flas...&height=513
Click Masterwerk once the Flash demo has finished loading.
Then under Act One click Variable Turbine Geometry.
I thought the new 997 Turbo was running twin VTG's. Its only a single?
While I realise that using a VTG system can mimic a twin-turbo setup with a much broader torque curve and more flexible powerband than a standard single turbo could provide on its own....it begs the question, why not just run twin turbos? Occams Razor, etc......
On any V engine (and a boxer engine especially), you hit plumbing problems with a single turbo. What's the benefit of going back to a single turbine rather than running a pair of turbines?
Imagine this engine with a pair of VTG turbos?
It's not the turbine blades that move on VNT turbos, it's the blades around the edge of the turbine that direct the exhaust gas on to it. It'd be impossible to do it the other way around.
Correct. In commercial aircraft engines they are called Nozzle Guide Vanes ( NGV's ) in the turbine or Variable Inlet Guide Vanes ( VIGV's ) in the Compressor. They change the angle of attack of the air going into the blades ( vanes in the case of turbo's ). Keeping in mind that in aircraft engines, the geometry of the turbine is not variable because of reliability and cost.
I'll be very interested to see how this goes into the future !!
The engine is going to need to run VERY cleanly to stop the guide vanes from siezing up with carbon build-up and I would imagine that the turbo service life on the new 911 would probably be an overhaul at something like 60,000km intervals.
Latest article I read, Porsche quotes 161,000km (100,00miles) for replacement or complete overhaul of the turbos :
I'd be extremely impressed if they can hold to that !!! ( and maintain full operating efficiency ).
These Garret VNT turbos have been around for about twenty years, nothing really new here.
They are not really suitable for petrol engines which is why Garret are pushing their GT ball bearing turbos for performance petrol engines, and the VNT turbos only for diesel engines. If these things worked as well as people think they do, companies like HKS would be offering them.
I ran a Garret VNT turbo on my Ford Laser for around two years so I can speak from plenty of practical experience.
You can order one from any Nissan dealer, part number is 14411-VC100 (charger assy-turbo). Back in 2003 it cost me $1454.55.
These variable vane turbos are the standard turbo fitted to the 4.0 litre Nissan Patrol diesel engine in Australia, and that particular engine produces 150Kw, so they are a rather small turbo. Two of these would be required on a larger engine.
Porsche seem to have made it work, where nobody else has. No doubt it took a lot of fairly sophisticated engine management and a lot of development. Don't think you can just bolt one on to your Skyline and get the same sort of results without the control system to make it work properly. There is far more to it han just hooking up a standard wastegate actuator to the vane control arm.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
