I beleive VW have been using variable vane turbos for years
Vw and Audi engines Use VTG turbos for there diesils , the petrol engines run a combination of k03/k04 KKK turbos.
Edited by Jolinator
I doubt if Nissan Australia will sell you spare parts cheaper with a bulk buy, but you can always try. Just go into your nearest Nissan spare parts and order a 14411-VC100 replacement turbo for a Nissan Patrol 4WD. This one took two days to come from interstate, but any Nissan dealer can get one in pretty quickly.
Some of the more recent small Mercedes diesel delivery vans sold in Australia now use VNT turbos too. I don't know how big these turbos are. The Nissan Patrol VNT is probably still the largest VNT readily available in oZ, except perhaps for Porsche. I don't know how much a new Porsche VNT turbo would cost, probably $6,000+ maybe ? And as Porsche use two of them, they may not be all that big either.
But you will also need to figure out a way to control the vanes. The Nissan control actuator looks exactly like a wastegate actuator, but it works entirely backwards. The vanes are held fully open by a spring in the actuator can. Increasing vacuum to the actuator closes the vanes. There is an adjustment screw to set (mechanically) how far the vanes can close at maximum control vacuum. When closed completely the vanes seal right up against each other, and all exhaust flow from the engine is completely blocked. But you can readily set the minimum vane opening position to best suit the engine. It looks a bit like the stop screw on an ordinary throttle body, and works in a similar way on the vane control arm.
You will want the vanes fully open all the time except when you want to see some boost pressure during acceleration. The vanes must then very quickly close. The vanes must then gradually open far enough to hold boost at whatever pressure it should be.
However you decide to do that, you are going to have to design and build your own vane controller actuator, and figure out a whole control strategy.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
