but yours is the black stallion - just come of age !
it was alive its currently engineless again with a cracked block :D n1 block time though and more machining and new rings and shes off again (about 2 months all up)
200km of hard driving and it cracked.
my engine goes in and out that engine bay like a yoyo
its a bare block again :(
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/127810-the-gang/#findComment-2363200
it was alive its currently engineless again with a cracked block :( n1 block time though and more machining and new rings and shes off again (about 2 months all up)
its a bare block again ;)
you should consider to treat all your engine componenys with cryogenic treatment. Meaninf seep freeze it with liquid nitro below -200C+. It said to strengthed the metal by at least 30% i think. I saw it years agoa in that documentary beyond 2000,
BLACK stagea hmm perhaps we should cut and past onto the pics a black unicorn if we can fin it :D . It will be cool.
https://www.sau.com.au/forums/topic/127810-the-gang/#findComment-2363237
    • I would like to add that at least in my car, the RPM gauge shows around 200RPM above of what I can see at nistune.
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
