but yours is the black stallion - just come of age !
it was alive its currently engineless again with a cracked block :D n1 block time though and more machining and new rings and shes off again (about 2 months all up)
200km of hard driving and it cracked.
my engine goes in and out that engine bay like a yoyo
its a bare block again :(
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/127810-the-gang/#findComment-2363200
it was alive its currently engineless again with a cracked block :( n1 block time though and more machining and new rings and shes off again (about 2 months all up)
its a bare block again ;)
you should consider to treat all your engine componenys with cryogenic treatment. Meaninf seep freeze it with liquid nitro below -200C+. It said to strengthed the metal by at least 30% i think. I saw it years agoa in that documentary beyond 2000,
BLACK stagea hmm perhaps we should cut and past onto the pics a black unicorn if we can fin it :D . It will be cool.
https://www.sau.com.au/forums/topic/127810-the-gang/#findComment-2363237
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
