OK, i have spoken to the Mike at MV automatics, and am seriourly thinking about ordering tomorrow morning an upgrade for my rb20 automatic gearbox, consisting of a 2800rpm high-stall and stage 2 shift kit
i want to know if anyone has gone down this route and can give me a description of how it drives?
Mike said that drivability is alomst normal and the converter still locks on the highway so fuel economy is almost normal too...
apparently their gearbox drives nothing like the traditional V8 high-stall gearboxes...
can anyone give me some insight??
cheers,
Warren
https://www.sau.com.au/forums/topic/127814-who-has-upgraded-to-a-high-stall/
parts have been ordered :D
should take about 1.5 weeks to get them all made and sent out, then i just have to put them in and i'm laughing!
mike thinks that even with the rb25 turbs on rb20 i should be able to get about 4-5psi at that rpm to help me shoot off the line!
13's here i come!!!
(ran a 14.7 @ 98mph with the current setup)
Hi,
i have a R33 4door. I have mikes shift kit, and recently installed a 2800 converter as well.
The shift harshness varies with your right foot, so its not always hard. But boy does it make the tyres work when it does shift....
As for the new converter, its pretty good. You notice it a little more in street driving conditions, but not too much. And the lockup still works a treat.
On the strip, (assuming you have good enough tyres to stall onto without spinning ), i was getting 7-9 psi with a quick stall at light throttle (since only got side mount cooler at that stage) .
Unfortunately, the 60' timers wernt working on the night i went out. but ET dropped from a 13.8 to a 13.2 However MPH dropped 4 mph
Not sure if this was converter, or due to the fact sitting on the line with boost fried the SMIC sooner and it lost top end......
Gary
i have a 2500 stall converter
from Dynamic Race Transmissions
along with my rebuilt box.
shifts are hard as.
its cost $600 for the converter.
Waz will your box be fully manualised after the stage 2 shift kit?
its still a std rb20det box right?
p.s my diff sounds like its copping a hiding if it changes from 1st to 2nd while rolling,you actually need to give it sum so it changes smoother
i don't want to say what i paid (people can call MV automatics for that) but it was just a bit more than what you wrote and that was for the shift kit AND converter
and of course different company means different product.. s they will perform differently..
its not manualised, just sharper changes...
the rest of hte box is standard... still rb20det auto box
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
