OK, i have spoken to the Mike at MV automatics, and am seriourly thinking about ordering tomorrow morning an upgrade for my rb20 automatic gearbox, consisting of a 2800rpm high-stall and stage 2 shift kit
i want to know if anyone has gone down this route and can give me a description of how it drives?
Mike said that drivability is alomst normal and the converter still locks on the highway so fuel economy is almost normal too...
apparently their gearbox drives nothing like the traditional V8 high-stall gearboxes...
can anyone give me some insight??
cheers,
Warren
https://www.sau.com.au/forums/topic/127814-who-has-upgraded-to-a-high-stall/
parts have been ordered :D
should take about 1.5 weeks to get them all made and sent out, then i just have to put them in and i'm laughing!
mike thinks that even with the rb25 turbs on rb20 i should be able to get about 4-5psi at that rpm to help me shoot off the line!
13's here i come!!!
(ran a 14.7 @ 98mph with the current setup)
Hi,
i have a R33 4door. I have mikes shift kit, and recently installed a 2800 converter as well.
The shift harshness varies with your right foot, so its not always hard. But boy does it make the tyres work when it does shift....
As for the new converter, its pretty good. You notice it a little more in street driving conditions, but not too much. And the lockup still works a treat.
On the strip, (assuming you have good enough tyres to stall onto without spinning ), i was getting 7-9 psi with a quick stall at light throttle (since only got side mount cooler at that stage) .
Unfortunately, the 60' timers wernt working on the night i went out. but ET dropped from a 13.8 to a 13.2 However MPH dropped 4 mph
Not sure if this was converter, or due to the fact sitting on the line with boost fried the SMIC sooner and it lost top end......
Gary
i have a 2500 stall converter
from Dynamic Race Transmissions
along with my rebuilt box.
shifts are hard as.
its cost $600 for the converter.
Waz will your box be fully manualised after the stage 2 shift kit?
its still a std rb20det box right?
p.s my diff sounds like its copping a hiding if it changes from 1st to 2nd while rolling,you actually need to give it sum so it changes smoother
i don't want to say what i paid (people can call MV automatics for that) but it was just a bit more than what you wrote and that was for the shift kit AND converter
and of course different company means different product.. s they will perform differently..
its not manualised, just sharper changes...
the rest of hte box is standard... still rb20det auto box
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
