Id recomend the 300v 10/40 its great the line loves it, oil filter cant go past genuine Nissan their cheaper than all the others and come pre-lubed ( the only cheap nissan part ).Gearbox i just use Castrol semi synthetic
https://www.sau.com.au/forums/topic/127827-what-engine-oil/#findComment-2364639
Is the Motul 8100 a true synthetic oil or just a modified mineral oil with synthetic on the lable? The reason i ask is because on their site the other synthetic oils specifically say they are ester based, but not the 8100.
I am currently using Motul 8100 but may change if it turns out it is not a true synthetic.
https://www.sau.com.au/forums/topic/127827-what-engine-oil/#findComment-2365766
There's not much info out there on the stdish range of Fuchs. I looked at it and really tried to dig up some voa's and uoa's with little success. :(
There silkolene range however is a very nice oil but isn't available anywhere in Adelaide that I know of.
https://www.sau.com.au/forums/topic/127827-what-engine-oil/#findComment-2365875
The 8100 is a full pao based oil.
It is a 100% synthetic as are mobil 1 etc.
The next step up is a ester based synthetic oil.
Actually .... its a lil more complicated than that. :(
Apparently their 8100 E-Tech 0W40 is a PAO/Ester blend whilst their 8100 X-cess 5W40 is a Group III blend. Hence the fair price difference too. Real world differences? Probably not much unless you do long drain intervals, a rarity on SAU. :O
https://www.sau.com.au/forums/topic/127827-what-engine-oil/#findComment-2366007
Who knows. :(
I emailed Motul some time back and they replied it is a 100% PAO oil with the E-Tech being a PAO/Ester (Group IV/V) blend.
I believe PAO can only be GRP IV?
Why manufactures don't list exactly what the oil is on their web site is beyond me. :O The only mob that do is Mobil.
https://www.sau.com.au/forums/topic/127827-what-engine-oil/#findComment-2366072
So the 8100 is ok to use, it was just wierd that its discription was so broad. It didn't even mention that is could be used in turbo engines. I'm guessing they want to talk up the more expensive oils so we buy them and not the cheaper ones that can probably do a satisfactory job.
At the end of the day i don't know anything about oils, i can only go on what i pick up here and there.
https://www.sau.com.au/forums/topic/127827-what-engine-oil/#findComment-2366103
Whats it worth.. Last I checked I think it worked out some where around $120 for an oil change with 1ltr to spare. So next change will be slightly cheaper.
I'll go the 10w40.
oh the thought of a ester cleaned motor so clean you can eat off it. :(
https://www.sau.com.au/forums/topic/127827-what-engine-oil/#findComment-2366224
