hi guys
Iam finally in the process of making my own Air Box for my R32 GTR, started it today and hopefully will have some pics up while iam step by step process. Probably covered already dont know...but ive got greddy hard piping with Z32 AFM/s and HKS pod filters. Not sure what to use either stainless steel 1.5mm or use perspex/carbon fibre sheets. If i do go for the stainless steel will prob get it down on AUTOCAD and get it laser cut for more professional look. Going to include the cost of making this kit so if anyone else that is going to do the same gives them better idea.
Here is what i have done so far.
1)Take measurements of the engine bay where pods are and the air flow metres and how they sit etc...took them down on a piece of paper and drew out a rough outline of the shape and sizing.basically going to be two main sides the side and top. the hardest is the side as youve got to contend with AFM and the curves on the body of the car and wires that run across.
2)After this process was done... I drew it up to actual size on a relatively stiff cardboard so it wont easierly wont bend. Obviously you wont get it 100% right with measurements. After cutting the shape out...place the cut out in the position you want it to go..and see if any gaps appear...all i did was cut off piece n used sticky tape to fill in gaps and cut it to the right shape. the hardest was getting the AFM holes right.
Did the same for the top of the Box that was much easier..only lil problem was the bonnet stay gets in the way and a lilttle gap has to be cut so the stay can fold down to its orig sitting position still. This left a gap at the bottom which the pods can b seen still thru small opening(last pic)...that can be covered with another piece.
just at this stage atm...will post when i get further in making the box
https://www.sau.com.au/forums/topic/127838-custom-air-box/
  • 3 months later...
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
