SOLD SOLD SOLD SOLD SOLD
17" Bronze SSP Type C 6 spoke wheels
Set of 4 brand new wheels, in boxes, never used on a car.
PCD: 5x114.3
Offset: +35
Suits R32/R33/R34/S14/S15/Z32 and various others including Daewoo Leganza, Mitsubishi Eclipse, Honda Accord, Honda Prelude, Honda S2000, Honda CRV, Honda Odyssey, Hyundai Tiburon, Mazda 3, Mazda RX8, Nissan 350Z, Nissan Maxima, Toyota Camry, Toyota Avalon, and Toyota RAV4.
Location: Pennant Hills, Sydney, NSW (15 mins from Epping, Hornsby or Castle Hill).
Postage: Willing to freight interstate. It will cost ~$80 to send the set to capital cities.
Price: $800 O.N.O.
Contact: Mark, on 0422 046 486.
The wheels are very pretty. You can't appreciate how great they look until you see them in natural light. They are an imitation of the popular SpeedyStar (SSR) Type C 's.
Edited by MarkE
  • 3 weeks later...
Hi mate, PM sent.
For anyone else interested, from what I can tell BusFreight can send the set of wheels for ~$60, Australia wide.
I will call them on Monday to confirm this.
Cheers,
Mark
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
