gtr 33 s1 style front bar $250
http://i12.photobucket.com/albums/a241/5ky/IMG_2423.jpg
gtr 33 s1 style front bar $200
http://i12.photobucket.com/albums/a241/5ky/IMG_2424.jpg
r33 gtst maroon back lights pair $100
http://i12.photobucket.com/albums/a241/5ky/IMG_2425.jpg
r33 gtst red rocket cover $80
http://i12.photobucket.com/albums/a241/5ky/IMG_2426.jpg
r33 stock front bar $70
http://i12.photobucket.com/albums/a241/5ky/IMG_2428.jpg
r33 k&n air filter with adapter $40
http://i12.photobucket.com/albums/a241/5ky/IMG_2431.jpg
http://i12.photobucket.com/albums/a241/5ky/IMG_2430.jpg
r33 gtst air filter cover $50
http://i12.photobucket.com/albums/a241/5ky/IMG_2434.jpg
http://i12.photobucket.com/albums/a241/5ky/IMG_2433.jpg
r33 gtst coil cover $20
http://i12.photobucket.com/albums/a241/5ky/IMG_2437.jpg
r33 gtst stock intercooler kit $50
http://i12.photobucket.com/albums/a241/5ky/IMG_2438.jpg
r33 gtst stock fog light $40
http://i12.photobucket.com/albums/a241/5ky/IMG_2443.jpg
http://i12.photobucket.com/albums/a241/5ky/IMG_2442.jpg
r33 trust wing $70
http://i12.photobucket.com/albums/a241/5ky/IMG_2444.jpg
r33 air filter metal chrome cover $70
http://i12.photobucket.com/albums/a241/5ky/IMG_2449.jpg
http://i12.photobucket.com/albums/a241/5ky/IMG_2448.jpg
r33 gtst s1 stock coil pack $150
r33 stock black oil cap $5
http://i12.photobucket.com/albums/a241/5ky/IMG_2451.jpg
r33 gtst caliper rears $150
http://i12.photobucket.com/albums/a241/5ky/IMG_2452.jpg
located in syd
BIG items pick up only, will only send small stuff to interstate buyers
:D
Edited by 5ky
https://www.sau.com.au/forums/topic/127853-parts-for-r33/
liek i said not posting big items, pick up only
fronts are sold only rear calipers left
and its not primered, u need to sand and primer it again and spray
the filter came out of 107,xxxkms r33, thats when i bought it. and changed to a better one
so i have no idea of its history
https://www.sau.com.au/forums/topic/127853-parts-for-r33/#findComment-2415142
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
