u can have bigger better brakes on the front, but obviously at some point the car would do an endo!
My thoughts on the matter after having finished a sensible $$$ upgrade to my car. (in case someone out there is interested)
I have aftermarket front rotors on my R32, (330 x 32mm) and brake balance is fine. So dont be concerned with brake bias.
I have a small problem with locking rears at the track, but that has more to do with the pad compound not coming up to temp as quick as the fronts.
One thing ive noticed with my slotted discs, is that the slot does not go to the very outer edge of the rotor, so when the slots fill with pad compound, and due to inertia heads to the outer edge, the pad dust has nowhere to go and begins to accumulate their.
After a short period of time a groove is now being worn into the discs about 7mm from the outer edge.
No big deal and doesnt effect performance, but ideally if i had to buy again i would be trying to find rotors with slots to the outer edge.
Ive been told metallurgically you need much higher quality materials to be able to do this and still avoid stress fractures and cracks propagating from the outer edge of the rotor.
Maybe because my rotors arent that high a quality they are unable to do this.
  • Replies 61
how much for slotted standared sized r33 gtst rotors front and rear? when will this be done? i am in need of some verrrry urgent because my rear ones i had for my car were buggered without us even being able to see it so i need to get new ones, i thought might as well get new all around
i asked autobarn for a price they havent gotten back to me
so please
URGENT! ehhehe
Just a FYI for the n00bs like me...
My local "Better Brakes" mechanics (do my whole families braking needs) said it would take between 1-1.5hrs to fit 4 new rotors at a cost of $65/hr labour.
So about $100 and they can be fitted (about 1/3rd of what i thought it would cost).
well i spoke to one of my mechanics he is getting me the rear 4000 series gold dba rotors
he said u cant get rear slotted only rotors for skylines yet only fronts in the 4000 series
and he said that for the 5000 series u actually need to buy new calipers
As I said in the first post I'll give it a couple of weeks...
As posted on 11/4/03...
Originally posted by red900ss
I'll tally the results and call them up next week. :P
It is now next week so take a pill :)
Originally posted by T0nyGTSt
Can you move the old fronts to the back?
My back ones look weedy.
T.
Front rotors won't fit on back.
Oh, and I'll have to withdraw from this deal too :) I measured my discs last night and they're only worn half a millimetre. Obviously been replaced at some point.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
