hi guyes
the thing overheated and now it wont start :D , it turns over a faster than usual and still wont start . ive come here for some help
things i have checked are
cam is turning as seen through the oil filler hole
turn on key to run and fuel pump is working and feeling the fuel lines they swell so i asume pressure is good
fuses are all good
crank engine and injectors feel as though they are firing good .. all of them..
im thinking the injectors wouldent fire if the ign pickup was dead .is this corect???
it is all looking to me as though there is no spark
will all the ignitor modules fail at once with extreme heat???
could i have fouled plugs??
Turns over faster than usual?
cast block.... alloy head. Sound like expensive compression issues to me - as in a warped head.
compression test...
of course, the igniters do get pretty hot, so its probably worth the time to pull a cupld of plugs and check for firing. Also, in the mean time, someone with more of an idea may reply... I still say warped head. how overheated was it?
compression test...
I have to echo what ebola said. You should conduct a compression test as a rough check that the head is still sealing.
And when you say overheated, do you mean there was steam under the bonnet or did the water temp gauge actually move into the wrong side of the dial?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
