help.. when i get into boost sometimes my s1 33 just doesnt boost up it sounds liek its sufficating but it only happens once abut every 5/6th time i put my foot down alot, and the other times it goes into boost without a problem.... :D
https://www.sau.com.au/forums/topic/127877-power-loss/
Could be all sorts of things unfortunately, you might wanna
Check your coilpacks for splits/tape them upp
Re-gap your plugs to .8m
replace your fuel filter
Check your fuel flow/pressure to ascertain pump condition
Check Your AFM, (carbie cleaner onto the sensor, run a multimeter, check soldering inside..Borrow1 off sum1 is easiest way to check if its faulty)
Try another/the original BOV
Check intercooler piping
Check for any boost leakes
Hope that helps
https://www.sau.com.au/forums/topic/127877-power-loss/#findComment-2363707
check all of the above, as well as the boost controller (if you have 1). i had a problem with a turbosmart boost controller where if you boosted up then changed gears, when you stomped it in the next gear it wasn't boosting up. turned out it was the boost controller not realeasing the air between it and the wastegate, so the wastegate was fully open when you jumped on the gas. i went back to my turbotech and all was good again.
https://www.sau.com.au/forums/topic/127877-power-loss/#findComment-2364041
hey mate,
this is just a bit of guess without getting into it too far, but i once had a 33 where the intake pipe from the air filter to the turbo would get hot and suck closed. would only do it every 5/6th run after some good fulkl throttle action.
hope this helps
gc
https://www.sau.com.au/forums/topic/127877-power-loss/#findComment-2365669
