Just wondering...
Any of you guys and gals have any idea what could be wrong? My dash lights wont work.
On sunday andrew ripped the standard stereo out and put in our new one. As of sunday night I now have no dash lights. Headlights are still working though.
A few people have suggested to check the fuses. We check them this afternoon and none are blown (every single one was checked)
I know that when you turned your lights on the climate control panel and the stereo lights would dim.... Could this have sometime to do with the fact that the lights aren't now working?
The climate control panel is still working.. just not the dash lights and the boost gauge light.
Any ideas would be muchly appreciated.
https://www.sau.com.au/forums/topic/1279-dash-lights-wont-work/
Hey Nismogirl,,,you say you both have check all the fuses,,,,did you check the 4 under the bonnet?. One is for the Tail lights,,,it has control over your dash lights as well. Test the Dash lights dimmer control,,,,yea that crap one installed for compliance,,,,disconnect it and join the wires together. One last one,,,,My Dimmer had scotch locks contecting it to the dash lights,,,,REMOVE them if you have them,,,,solder and insulate them.
Hope this helps...
neil
So the fuses for the lights are under the bonnet??
We looked at them but didn't take them out. Kind of just said "Hey theres some fuses!"
But... i'm not very mechanically minded. So... Andrew going away as of tomorrow and I think hes not fixing it on purpose cause he doesn't want me to drive the car. So i'll go somewhere and get it fixed.
I had the same problem, are your tail-lights blown as well?
When he installed the stereo, did he ground it to an exisiting wire he metered out?
I did that, and it just so happened to blow some fuses (Dash, and Tail lights), so I created my own ground. Get him to do that, and replace the fuse UNDER THE BONNET
Hmm.. Bonnet.. the thing at the front....
I had exactly the same problem in my 33.... and it took me a while
but i found the fuse i blew was at the back next to the battery in
the black casing.
Nismogirl, i'm not sure what car you drive but i assume its a 33?
Hope this helps. It's a 10amp fuse.
Originally posted by NismoGirl
Well I'm stuck now
Andrews not coming over and I've now realised I also have no tail lights..
And I'm as mechanical as a potatoe... so I can't fix it
:P
I think i might cry right now
I had a really good weekend planned too :cuss:
Ah Nismogirl we can guide you though this little problem easily...:burnout:
Pop the bonnet,,,,remove the Black cover,,,the one that has the + sign on it. Bit tricky if you have long finger nails,,,just pull the tab outwards(its just behind the + sign) and lift the lid off. The fuse you need to replace is the one closest to the headlamp. Using your tweezers,,,yea you got a pair in your handbag,,,pull out that fuse and replace it with a new ....10a Fuse and I'll bet if you test your tailamps now you'll have them. Put cover back on and all Should be okay. Program Radio stations,,,grab some CD's and go cruising.:O
ok.. now i feel like a dumb blonde.. I'm not THAT much a potatoe
I've replaced the fuses (are there only meant to be two in the front.. cause theres four spaces) and the lights still dont work.
Actually i replaced both fuses.
So whats another plan guys... I still haven't tried re earthing the stereo.. cause i dont know how and i dont want to break the nice new stereo.
Sorry Nismogirl,,,,I didn't mean it like that,,,,,Okay so you only have 2 fuses under the Bonnet,,,were they blown?. If not we have to find where your Tailamp fuse is located. Your car is not like mine then,,,,maybe yours is in the Boot.
Guest Crazyfcuk
I had the same problem last week. fixed up my left hand light and found a male and a female plug next to my lights, connected them and the lights blew. (exactly the same lights as what has happened to urs).
In my case it was a fuse in the fuse box in the boot next to the battery, 2nd fuse in (should be a diagram on the fuse box explaining which is which) Its a 10 amp fuse (red i think) pull that out, if your having trouble there is a fuse remover in the fuse box inside the car to the right and below of the steering wheel. use that and check the fuses in the boot. I can almost guarantee that its in there cause i just fixed mine.
  • 6 months later...
Gee, what a phuqqin' surprise...
I had my radio installed dodgy brothers style and now I got no dash lights or working front running or rear running lights.
Brake lights and headlights work fine so daylight driving is ok.
I might have to print out this thread and pass it to my local electrician.
T.
Most likely cause of all those problems is the incorrect connection of the illumination wire (eg, shorting to ground) during stereo installation. Check fuses in boot next to the battery (R33). However, before you replace the blown fuse, be sure to rectify the wiring problem, otherwise the fuse will just keep blowing.
i'm with ylwgtr...
Check your dash dimmer switch - my dash lights went soon
after my car was complied. i just disconnected the wires from
the dimmer and joined them bypassing the dimmer all together.
It will stay on full brightness though without the dimmer of course.
Not sure if my tailights were affected as well at the time.
The two could be related if your fuses are all fine.
Definitely sounds like the head unit has been wired incorrectly. You'll probably find he has grounded the stereo to an interior light signal wire which shows as an earth wire until you actually switch the lights on, it then goes to +12v. I have seen this a few times before, a very common mistake when installing head units
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
