i took my hicas lock bar in to get installed today and the guy said i need some bolt/plugs to screw into the lines that you disconnect so that power steering fluid doesn't go everywhere.
Does anyone know the size of the thread that i need to buy?
https://www.sau.com.au/forums/topic/127910-hicas-line-thread-size/
if you block the lines, it will kill the rear stage of your power steering pump.
Do not do this.
The correct method to loop the lines in the engine bay is here
http://www.skylinesaustralia.com/forums/in...howtopic=122140
cheers for that, couldn't find that thread when i searched, thinking i might pay someone to install it cause it all looks a bit confusing!
Did you read it? If you just block them off, your powersteer pump will fail!
So you make the decision wether you want to spend a little more money now to loop the fluid to the cooler or spend alot more later to fix what ever you've broken after plugging the line?
I would suspect that no one knows what thread size it is, as this is the wrong way to go.
i'm sorry i did read it but i'm confused as the guy i took it to, to get installed said i need to find the bolts/plugs so i just did as he asked cause he's the man everyone recommends in adelaide so i thought he'd know what he's talking about more than i would!
i'd do it myself but i'm no good with this type of stuff and i'd be worried about screwing somthing up!
well, he's wrong
If you bypass it properly, you can remove the lines all together, and it also doesn't wreck your power steering pump, and it also retains the power steering cooler (that's another thing you won't get if you just block up the lines rather than looping them)
I was looking at it from a very capable point of veiw! :D
I think your best plan of attack is to get the pics off the other thread and if you choose this guy that everyone recomends, show him the Photos and any other relivant information and "ask" him if he could do this for you! Then you can remove everything from the reroute back and have it done the right way.
If he says no, then take it somewhere else. But to be fair to the tradey, it would be acceptable for him to add $50 or so on top to carry out the loop and remove all the hoses and main unit in the engine bay!
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
