Hiya :teehee:
Just got my car (S13 Silvia) back from a wheel alignment, however it was only a month or 2 ago since my last one but during that time, I've managed to gain almost +2 to 3 mm toe on the rears? Most of my other alignment settings remain fairly close to what they last left it with which is why I'm a bit curious as to why this might happen... bushes going perhaps?
And to note, I haven't changed anything in the rear besides change rims once. Or is this change just normal?
Old alignment for rears
- Left = +1mm
- Right = + 1,4mm
Today for rears before adjustment
- Left = +3,8mm
- Right = +4,4mm
They've since adjusted it back to about +1mm.
Also while I'm at it, I was hoping on slightly less rear camber but the max they could get it to was -1.25~
I WAS planning to lower the rear by about 5mm but that would just make my situation worse, so... would aftermarket offset bushes be sufficient or should I start looking at arms? I'm guessing Toe arms may also be needed?
Thanks in advance for any advice/suggestions/answers...! :P
https://www.sau.com.au/forums/topic/127928-alignment-queries/
Funny things cars, and when you read wheel alignment specs they never seem to make sence how one day they are one reading and another day they can be another reading.
Every machine will be out slightly to other machines, unless they are calabrated exactly the same way by the same person every time, so from place to place the Alignment machine might be calabrated every week and the next place it might be every 6 months, No real way of saying what one will be more acurate though.
But basically if you went to a different place for each alignment this may be one reason why it is different in readings. from the last alignment to the first reading on your second alignment. also if you drive the car hard or even hit pot holes in the road and stuff like that, that most of us cannot avoid, or even live in a suburb that thought it was a good idea to make there driveway entrances at a horrid 45% angle, then every time you hit a pot hole, or go up your driveway it could be altering your toe slightly.
Or the first place that aligned it didnt do it right and botched up a read out.
Also your bushes could be on the way out.
You can choose.
But yes alignment specs will change from place to place, from 1 month to the next depends on where and how you drive.
Edited by DaFuca
Thanks for the reply...
I only get them aligned at the one place. But when I compared my other values like camber for the front change .2 degrees which didn't surprise me as much as the rear toe change? I'm gonna point the finger at bushes I think <_<
Hiya :)
- Left = +1mm
- Right = + 1,4mm
- Left = +3,8mm
- Right = +4,4mm
Thanks in advance for any advice/suggestions/answers...! :D
No HICAS
Adjustable bushes will correct the camber.
Toe change is usually caused by;
1. Accident damage, hit anything lately?
2. Worm ball joints/bushes on the steering arms, I assume the aligner checked for that?
3. Loose adjuster, any sign of the lock nuts not being tightened when the last alignment was done?
:D cheers :D
Edited by Sydneykid
Sk, does toe change affect the car veering to the left??
I forgot to ask ECS what my front toe is at..
(just got adjustable castor rods put in) Car is much more firm and stiffer, but at times it still veers to the left. A lot less now, but i have a feelin it could be my old tyres also..
Or do i need my radius bushes replaced??
Cheers SK.. :)
Edited by siddr20
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
