BRAND NEW IN THE BOX JVC KD-DV4205 DVD PLAYER
IM IN MELBOURNE NORTHER SUBURBS WILL POST AUSTRALIA WIDE FOR 10 BUCKS ASKING $300 GET A MP3 DVD PLAYER AT THE PRICE OF A CD PLAYER CALL ME ON 0401267277
HERES THE SPECS
Power Output: 50W x 4 Max.
MOS-FET Power Amp
GIGA MP3
cEQ
Ready for iPod®*
DVD-R/-RW, +R/+RW, VCD Compatible
MP3/WMA Compatible with ID3/WMA Tag
CD/CD-R/CD-RW Compatible
DTS/Dolby Digital/MPEG Audio (2ch)
24-bit DAC (Audio)
Line Output Terminals
Video Output Terminals
Optical Digital Output
Rotary Encoder Multi-Control
Multi-Function Wireless Remote Control
*In conjunction with KS-PD100
DVD Section
Video Format: NTSC/PAL
Zoom (for DVD)*
Chapter Access (for DVD)
Pause/Step/Slow*
VCD Playback Control
Direct Track Access (for VCD)
Last Position Memory
*Remote control only
CD Section
CD Text
Direct Track Access
Random/Repeat/Intro Play
+/- 10 Skip Function
Changer Control Section
MP3 Control*
CD Text*
Direct Disc Select (1-12)
Random/Repeat Play
Skip/Search
* In conjunction with CH-X1500.
iPod® Control Section*
Play/Pause
Skip/Search
Random/Repeat
Text Display
Tuner Section
HS-IV Tuner
IF Filter
18 FM and 6 AM Presets
SSM (for FM)
Seek (Up/Down)
AFNS/PNC
Stereo/Mono Switch (for FM)
Auto Antenna
Amplifier Section
Source-Specific Volume Control
Balance/Fader Control
Volume Attenuator
Loudness Control
Max. Amp Gain Switcher
Display Section
Multi-Color Display
Switchable Dimmer
Power Switch Standby Illumination
General Section
Detachable Control Panel with Carrying Case
Power-Off Mode Eject
COMPU PLAY
Preferred Setting Mode
Edited by hiboostgtr
https://www.sau.com.au/forums/topic/127969-new-jvc-car-dvd-player-in-box/
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
