Valve Body Clean + Auto Box Oil Capacity
hey guys,
im just wondering about how i would go about cleaning the valve body on my auto box.
is it just a matter of pulling it out and giving it a scrub?
also, what is the oil capacity of the auto box in the r33 gtst's?
cheers.
i changed it, it seemed to be around 3-3.5L, also consider ive got an aftermarket oil cooler.
i might do a DIY on how to do all this including how to clean out the filter as i took pics as i went along.
let me know if there is any interest and i'll put it all together.
cheers.
i didnt even bother trying for the torque converter. just did a filter clean.
i wanted to take my valve body off and give it a clean but i couldnt be bothered at the time. the oil change has almost wiped out my 'getting stuck in 1st' problem, it used to do it almost 15 times a day. it only did it a few times earlier tonight, and by the end of the night it was running smooth.
i have heard that you can do the following to get all the fluid out.. but it doesn't clean the filter for you..
- undo the hose to the radiator for the stock transmission cooler
- place one end into a bucket
- start engine
the fluid will pump out in very quick time
then turn car off immediately after fluid is out
then fill her up!
i'm not game to do this, however, as i'm not sure if having the transmission running without fluid, even for 2 seconds, would be a problem or not
anyway, glad it went well for you
post up a guide if you can be bothered :wave:
- start engine
yeah i dont think it'll be a good idea to do that either. in the instruction manual for the davies craig trans cooler kit i got, it said to do that just to determine which hose is the feed and which is the return.
also, the car only did the getting stuck in first thing once today. i want to take my valve body off and give it a clean. i plan to run my car down the 1/4 and i dont want it happening to me then either.
i'll post up the guide soon :happy:
  • 3 weeks later...
for a quick flush pull a line off the trans cooler prefer after the cooler for a cooler flush aslo.
get a bucket big bucket.
get some fluid lots of it.
run the car with the hose off and faced in the bucket.
at the same time fill the box with cleen fluid
watch the fluid comming from the hose in to the bucket and when it comes cleen turn off motor
reconnect lines and check fluid level
CAUTION: IT WILL TAKE MORE THAN 10L SO HAVE LOTS OF FLUID HANDY
20L of dextron 3 cost me 80 something dollars (been awhile)and it also helps im a mechanic with access to the w/shop on the weekend...
Edited by rb25_vl
...Although i didnt know you could use Dexron III....always thought it was something else????
Can anyone else confirm?
Yeah Nissan specify to use Dexron III, Ive been using Castrol Transmax Z for the past 11,000+kms & with 107,000 on the clock & over 200kw atw the trans still goin strong :happy:.
Edited by pkblade
 Share
    • its been that long i forgot about the wrx.
    • Any chance the zero demand ignition table is messed up? Or possibly the minimum tps for it to engage zero demand?
    • 32010-AA520 - R34 RB25DET manual transmission, you can buy this new. You'll need a pull to push type clutch converter (to use R33 clutch kits), or buy pull-type clutch (R34 clutch).   R33 part number if you're lazy: 32010-21U00     Applies: RB25DET.MT.F5; Notes: FS5R30A
    • Hi All, Ive recently pulled my head in and gotten started on my 2year long project for my R32 RB25 swap, I went into it head high and confident it was an easy swap and plug and play wiring. I was wrong. The engine is a S1 RB25 and I'm running RB25 ECU And loom. I got the swap done a few weeks ago and have been working on the car on my time off, however i cannot get the engine to run, at first the engine would crank however the fuel pump would not run,  i dove a little deeper and realised that i would need to connect the wires from the RB25 Body Loom and the RB20 Body loom. went through the ECU pinout and followed the wires from the Body looms one by one to find what was needed to start the car. Now I have rewired the RB25 loom with the old R32 Body loom attached, however i am still having issues starting the car, now the pump works but still wont fire.  The car has spark but looks very weak, however I'm suspect that its not getting any fuel. I have read a few posts related to the "Main plug" near the air intake however cannot find any information on what wiring to hook up to where.  If anyone has done this swap, or has any knowledge at all on RB25's into 32 i would really appreciate your comment regarding this, im really keen to get this car finished.  Thanks in advance
