G'day all
I would like to say thank you and best wishes to you all, I have been around fourm for while now, and this is pretty good place to start out if you have questoins about skylines.
I will be flying out to south korea this Sunday, to serve my mandatory millitary service for next 3 years.
I would like to thank all the current and old SAUWA members and staff, especially Dan the man and Sneeza. you guys are doing great job to make every members happy, and that is not easy task. but you guys are doing well.
I thank you all and will see you all when I come back, hopefully by then R35 GTR is affordable :D
cheers
Joe
https://www.sau.com.au/forums/topic/127998-pva_glue-is-going-back-home/
G'day all
cheers
Joe
Bye Joe,
Keep Safe
Paul
G'day all
I thank you all and will see you all when I come back, hopefully by then R35 GTR is affordable :(
cheers
Joe
Hope the next 3 years fly past Joe!
Look forward to seeing you back in Perth driving a R35 GTR!! :D
Thanks for the sales you have forwarded onto my shop I wont forget!
- Adam
Hi Joe,
I didn't realized you're Korean ? With the current climate I think I'll choose to be a coward than do compulsory military service :D. Send back some photos while you're over there ..
Anyway, take care and keep safe. See you in 3 years time.
Richard.
G'day all
cheers
Joe
Pea Grabel, no but we have land mines :D
I still have nasty scar from that :nyaanyaa: thank you both and everyone.
I will be back in 3 years, I will still keep in touch and take heaps of photos also I might travel to Japan (only 1 hour flight out of Seoul).
so If anyone planning to go japan, you should drop into korea and look me up.
I can be contacted @ HONGAS@GMAIL.COM
I will make own bloggs on here so you guys dont miss me too much.
really I thank you all for Great time in SAUWA and all the best to you all.
I am flying out sunday night/monday morning ;)
cheers
Joe
Try and keep in touch Joe. When you are not fighting off the red from over the border. Hmm reminds me of "Tae Guk Gi" :pirate:
Too bad i didnt make it on Sat i ended up getting caught up in some family drama much to my distress.
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
