Up for sale is my beloved R32. the car has 132,xxx's on it and has been alround a pretty good reliable car. at 100,000 installed a new water pump, all belts ( gates racing timing aswell ), cam seals, crank seals.
list is as follows.
Engine
RB20DET – 130,xxx ‘s on car
GTR CLUSTER – WITH 83xxx’S ON CLOCK
NO RUST THROUGHOUT CAR
T3/T4 TURBO ( 1BAR BOOST ) (5000k's old)
HYBRID FRONT MOUNT – CUSTOM PIPING
CHIPPED ECU WITH 2 OTHER TUNES
APEXI SAFC I ( blue screen )
3” TURBO BACK EXHAUST – 4” CANNON MUFFLER
HI-FLOW CAT
550hp WALBRO FUEL PUMP ( IN TANK )
STAINLESS STEEL AIR FILTER
REPRAYED GUN METAL GREY WITH GTR STYLE BONNET
MONGOOSE IMOBOLISER ALARM
KEYLESS ENTRY, CENTREL LOCKING
GATES RACING SILCON TIMING BELT
NEW BATTERY
APEXI DUAL CHAMBER BLOW OF VALVE
CLEANED INJECTORS ( 8 MONTHS AGO )
SERVICED EVERY 4500 TO 5000 K’S ( with Penrite 10w-50 oil )
FULLY CLEANED AND FLUSHED RADIATOR SYSTEM
AIRCONDITIONING HAS BEEN CHANGED TO NEW GAS ( NEW ORINGS THOUGHOUT SYSTEM), REPLACED BEARING ON AIR CON
4 WHEEL STEER - HICAS
GTR GEARBOX 4WD
HEAVY DUTY GTR CLUTCH FROM DIRECT CLUTCH
GTR FRONT DRIVE SHAFTS
ADJUSTABLE CASTER BUSHES
ADJUSTABLE FRONT CAMBER BUSHES
PAINTED RED BRAKE CALIPERS ( NEW PADS )
18” RJR WHEELS ( BRAND NEW ) WITH NEW RUBBER 245/40R18
BILSTEIN HEIGHT ADJUSTABLE SHOCKS
LOWERED KING SPRINGS
VELOUR INTERIOR - NO HOLES IN FABRIC
MOMO STYLE STEERING WHEEL
INSIDE DOOR HANDLES PAINT METALLIC SILVER
AUTOMETER AIR/FUEL GAUGE
AUTOMETER BOOST GAUGE ( PSI )
SWOOSH BOOST GAUGE ( BAR )
PANASONIC MP3/CD PLAYER
PIONEER 6” SPLITS IN FRONT
PIONEER 6” TWO WAY SPEAKERS IN REAR
PRICE IS - $14,000 ono
rego till 10th month this year, comes with road worthy
Location - Brisbane / Ipswich QLD
will consider trade + cash
any q's email me at - [email protected]
thanks guys
Curt
sorry about pics - done on my mobile phone.
Edited by Mr GTS4
https://www.sau.com.au/forums/topic/128006-fs-r32-gts-4-4door-93/
  • 1 month later...
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
