sorry for the boring as post guys.
im just curious to hear a few comments stories etc. i have a LOUD AS rattle in my rear passenger side quarter. the sound is mainly when i am under heavy acceleration or hitting bumps, rough road surfaces, potholes etc. sometines at certain rev ranges. also when i turn the car off. thought it could be the exhaust rattling on something. thats been cleared. ive had the rear seats out once already looking for it. ive now comptely emptied my boot apart from the essentials (spare jack etc)
checked so far:
exhaust
bearings lhrear hub
removed all boot contents apart from essentials. (they are fixed tightly and arnt moving)
i cant think of anything else apart from gutting the whole left hand interior and going up the hills for a spirited drive.
has anybody had anything as annoying as this?
any suggestions as to what it could be would be awesome.
thanks in advance for helping me on my quest for a rattle/squeak free car! :D
https://www.sau.com.au/forums/topic/128019-rattles-rear-left-quarter/
  • Replies 45
Does it happen when idlling? Is it possible to describe the sound, does it sand like someone has put a coin in a metal jar and is shaking it? I was gonna say it could be your catalytic converter but if its comming from the rear left side then it wouldnt be.
Edited by R33_Rob
ive had all of my trims out and then driven te car. i can still hear it. the noise it too far rearward to be the cat plus its brand new. i dont get the noise when idling.
the sound would be kinda like metal vibrating on metal. im thinking it could be the hinges or latch mechanism on my boot lid. things always to turn out being the most simpilist things. yet i cant find it! thanks for ur help guys.
anyone else got any suggestions?
sorry to hijack this thread, but my R32 GTS has developed a rattle near the catalytic converter, just like you described. Whats the problem? how much will it cost to fix??
after having this rattling noise in my rear end for over a month, numerous hunts to find it, on and off the hoist. panels off, seats removed etc etc blah blah. i think ive narrowed it down the the rubber stoppers on the boot lid being too old and brittle. the boot lid looks to be sitting too low and i have wear marks on the tail light assembley from the lid hitting. also on the rear quarter panels from the spoiler hitting.
ill replace the rubber stoppers after pay day this week. hopefully this fixes my problems.
things most always work out to be the simplist of things...
If not, what I've done before was take all of the rear trim out of the car and have my brother drive it slowly up and down the dead-end street near my old place, with me in the back searching for the noise. In my case it ended up being the coax cable running to the aerial (rear left...) hitting the outside panel of the car - a clip had gone brittle and broken. A couple of zip ties to attach it firmly again and the noise went away.
Yes! i had this problem for a month it was driving me absolutely INSANE
Look under your car at the drive shaft and follow it down to your diff, you will see the handbrake cable. follow that down and most likely you will see that it has popped out of its holder hitting your diff, so as the driveshaft is spinning the handbrake cable is tapping it. Simply pop the cable it back in its holder
I had the same symptoms, it would rattle on and off at certain RPM ranges and it was a loud metallic rattle that was embrarrasing as.
Tell me if its fixed it!
Edited by Gengis
thanks for the ideas guys. itll be at the mechanics monday gettin the hicas competely gutted and a few leaking hoses replaced. ill check along the driveshaft then. its good havin a mechanic that lets u do anything u wanna and not kick u outta the workshop.
that loose coax cable for the aerial, is that in a 32? i dont have an external aerial in my car. its build into the front window.
ive had all of the left hand side panels out and the boot gutted. taken the rear seats out and the metal panel that divides the boot from the cabin. parcel shelf etc. sounds to be too high for it to be around the driveshaft but ill look anyways.
i hope i find the sucka soon as im goins bananas! :D
oh and just so u all know. if u get a really loud annoying squeak coming from ur dashboard, check ur speedo cluster. theres a competition in my car for the most annoying noise to bug me. the squeak has been found and a new speedo gets here in a couple of weeks thanks to slidewize and yahoo japan.
just gotta source that damn rattle! :nyaanyaa:
A catalytic converter for an r32 start around $200 (IF your lucky that shoudl include installation aswell).
But that is just a regular catalytic converter and not a high flow.
EDIT: julion if u want to be sure if your catalytic converter is making that sound quite simply punch it. Lay down beside your car and knock the cat, obviously dont punch it as hard as u can. If it rattles the noise is ur cat
Edited by R33_Rob
Ron it might even be some loose part that has fallen down inside the rear quarter panel. I had my right rear replaced when I painted the car and inside I found:
a D-cell battery
a spark plug removal tool
a diary (in Japanese)
a single woollen glove
my original gearshift
so yeah I worked out what the rattly noise was... :happy:
Good luck with yours dude
sorry guys but ive already found all the crap inside my panels. anybody like golf? i got about 20 wooden tees along with 3 empty spark plug packets. ive taken the spare wheel out, the jack and tool kit etc. all of the carpet and panels so my boot was a bare shell. (so good to see no rust!)
im picking up some new rubber stoppers from nissan tomorrow.
anybody seen that computer lookin thing thats located inside the left rear quarter panel in front of the jack holder? WTF is it??
a D-cell battery
so yeah I worked out what the rattly noise was... :D
i love ur pic mark!! gold
Thanks! That's Jamie the spraypainter holding my 'non-accident damage' rear quarter from my R32 :happy: Note the spot welds along the back of the wheel arch. See how many rust spots you can find :yes:
By the way Ron how did you pull that stuff out? Did you use one of those long claw tool things - the ones good for picking up the bolts you drop in the engine bay? Nicely done mate!
Thanks! That's Jamie the spraypainter holding my 'non-accident damage' rear quarter from my R32 ;) Note the spot welds along the back of the wheel arch. See how many rust spots you can find :)
no special tool for it mate. im just a skinny bugger and i can get my hands in all kinds of small spaces :) there was a little bit of mud in there as well so i took it out and replaced it with fish oil so my panels wont look like urs. :(
Have you checked your spoiler? I had a U13 bluebird and the wing on it was coming away from the bootlid and would send a vibration through the car at certain RPM
the spoiler is on tight as. the rubbers a pretty well cactus though. ive ordered new 1s and ill pick them up thurs along with new door seals $$$:D
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
