I was filling up my water tank for window cleaning in the car and accidentally spilled some droplets of water to the right of the plastic tank on this plastic connections... i wiped it off but last night my right head light wasnt working! :D
Can anyone tell me what could be the issue? Blown fuse or did i blow my head bulb?
https://www.sau.com.au/forums/topic/128037-lol-shit/
Sounds like it might be a coincidence, those connectors are pretty water resistent. Think about how much water would get into that area driving in the rain, and compare to the amount that you spilt. Make sure that you didn't knock the connectors loose though.
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2366850
whaever you do, dont drive at night. sounds simple, but once i was drving frmo penrith to wollongong in the chaser, and i didnt know until it was too late, but both my headlights were out.
i didnt realise while i was on the M4 and main roads where theres lighting, but once on the hume I had two choices: high beams and live, or no lights and porbably veer into the dirt and make some crashing noises.
this post is no help at all, sorry
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2368342
It's most likely those rice bulbs that you have. Those whit bulbs look nice, but I have never found some that last. When I first got my car, I went through about 3 packets (6 bulbs) in about 12 months.
But check it before you replace it.
What I found when they blew was it happened when i turned it on. It'd go on, then turn off striaght away and it's like shit, there goes the bulb.
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2368747
The lights on R33 S2's are not driving lights, they're only good as fog lights. Not sure what they're like on the S1 I haven't driven one at night. If you used one in an emergency I wouldn't recommend doing more than 20-40km/h because you can't see further than that.
R33 headlight connectors are filled with a weird whitish goop, which seems to dry over time. Heaps of people complain about intermittent headlights which start working if you whack them with your hand - this is just a poor connection issue.
When I replaced my parking lights I had the same problem, wiggling the wire slightly would make the light go on and off. I sprayed the shit out of the socket with an air duster and a bunch of crud fell out. Then I sprayed the socket and the plug with electronic contact cleaner and slapped it together and couldn't make it play up.
So your globe is probably fine just the plug isn't making good contact.
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2368986
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
