I was filling up my water tank for window cleaning in the car and accidentally spilled some droplets of water to the right of the plastic tank on this plastic connections... i wiped it off but last night my right head light wasnt working! :D
Can anyone tell me what could be the issue? Blown fuse or did i blow my head bulb?
https://www.sau.com.au/forums/topic/128037-lol-shit/
Sounds like it might be a coincidence, those connectors are pretty water resistent. Think about how much water would get into that area driving in the rain, and compare to the amount that you spilt. Make sure that you didn't knock the connectors loose though.
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2366850
whaever you do, dont drive at night. sounds simple, but once i was drving frmo penrith to wollongong in the chaser, and i didnt know until it was too late, but both my headlights were out.
i didnt realise while i was on the M4 and main roads where theres lighting, but once on the hume I had two choices: high beams and live, or no lights and porbably veer into the dirt and make some crashing noises.
this post is no help at all, sorry
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2368342
It's most likely those rice bulbs that you have. Those whit bulbs look nice, but I have never found some that last. When I first got my car, I went through about 3 packets (6 bulbs) in about 12 months.
But check it before you replace it.
What I found when they blew was it happened when i turned it on. It'd go on, then turn off striaght away and it's like shit, there goes the bulb.
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2368747
The lights on R33 S2's are not driving lights, they're only good as fog lights. Not sure what they're like on the S1 I haven't driven one at night. If you used one in an emergency I wouldn't recommend doing more than 20-40km/h because you can't see further than that.
R33 headlight connectors are filled with a weird whitish goop, which seems to dry over time. Heaps of people complain about intermittent headlights which start working if you whack them with your hand - this is just a poor connection issue.
When I replaced my parking lights I had the same problem, wiggling the wire slightly would make the light go on and off. I sprayed the shit out of the socket with an air duster and a bunch of crud fell out. Then I sprayed the socket and the plug with electronic contact cleaner and slapped it together and couldn't make it play up.
So your globe is probably fine just the plug isn't making good contact.
https://www.sau.com.au/forums/topic/128037-lol-shit/#findComment-2368986
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
