very interested buddy....just want to know how long ago did u buy this stuff? model numbers? still under warranty? still got reciets?
Edited by anjoO
https://www.sau.com.au/forums/topic/128038-sold/#findComment-2374402
I am looking at getting an alpine system myself - I have posted on the audio and alarms section of the site as to what I was looking at getting:
http://www.skylinesaustralia.com/forums/in...howtopic=129035
Pics would be great :thumbsup: - so i can compare them as well :P
https://www.sau.com.au/forums/topic/128038-sold/#findComment-2388732
  • 3 weeks later...
Im interested in your splits if you find someone else to buy the rest... Do you have pics of them? in boxes etc / receipts etc...
Cheers.
Keen on the rest of the system amp & sub and i would assume you have all the wiring that you need to hook up both of them rca, amp power wires,fuse etc??
If you this is still for sale please let me know.
Thanks Rob
https://www.sau.com.au/forums/topic/128038-sold/#findComment-2505687
Cheers.
Thanks Rob
alright that means between the two of you, it'll go
ill PM ou both with the prices
https://www.sau.com.au/forums/topic/128038-sold/#findComment-2522842
  • 3 weeks later...
    • Don't think that can fit in physically. Are you referring to this?    If it happens again, I'm going to get the nismo ones.
    • I bought the 1/18 scale celica and nsx from Justin and they are very detailed and good quality. I will definitely be interested in others in the series as they come out
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
