i would like to go but i dont know anyone on this forum so i think i might give it a miss, plus im a p plater and cant drink any beers :) hope it al goes wel tho :)
DW if we are cruising i think alot of ppls wont be drinking
all i know is im cruising upto the big rocking horse, to be there @ 5pm to pick my daughter up so we could all cruise that way there is a big car park there ;) and then onto the whispering wall after
  • Replies 280
Posted Images
i probably will only have a few myself so ill be taking it easy. like the name tag idea, last cruise i went on couldnt work out who was who. altho i dont think my chest will pop the name tag out enough lol
Yeh Jared maybe we should have some stickers on hand so when people rock up they can write thier 'username' or 'real name' or even both and wear it........... wherever they want eg: chest or forehead!
This is not such a bad idea, as there will be a tonne of people there I don't know & just to confuse everyone I've changed my username ;) (it was Electro). Have you nominated yourself for the job Deluxe???
Ahhhhhh Crap........ Well i guess it depends on how you work the day and if i'll be there to start with(should be)! But it might pay to maybe book a room out and that way we could have this sticker pad thing at the door so people can do it them selves, because there is ALOT of people i still don't know i here too, and it would save one of us running around asking every random person if they're with SAU!
Haha it's ok, you don't have to do it ;). Not a bad suggestion though.
If anyone else know's they will be coming & can easily get ahold of a deacent labelling machine or label printer it would be handy though. Will keep this in mind if I get time.
you should add a voting option on this thread itself rather then pm. so everyone see's which one is the most favourable location. or make a new thread with a voting option.
Really if people want to come they will request a PM. I'd rather people that are actually going to come to vote, rather than letting everyone vote only for half of them not to turn up, & then the people that do turn up to complain they wanted the other joint.
I also don't want 20 unaccounted for people rocking up & then we find out we don't have enough room or something stupid. So the idea is to keep everything as in control as possible >_< . It'll save a lot of heartache for me later.
Yeah I'll leave it up to the voters to decide rather than overrule it now. The only reason I may change the venue is if we can not get in to the most popular one at close of votes. If a majority appears beforehand I will make the booking, at the moment though it's pretty even.
Oh 1 thing I forgot to point out people about the ale house. If we go there we'll be in a courtyard area as the bar will not be big enough obviously & if we have enough numbers we'll get the area to ourselves.
good show
wots every 1's thoughts on following me upto the rocking horse and then onto whispering wall
Is this a family thing? the meal etc...... my 3yrold would love to see the giant rocking horse.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
