How Strong are the R33 GTS internals.
This has been discussed a while ago, but i think it was off topic in some thread. This thread would be well mated to the turbo converion thread.
Are the Gts internals, connecting rods, pistons, etc the same as the Turbo varient?
It would make sense from a manufaturing point to view to only make the one set of internals for the majority of the cars.
Obviously, there are difference, just have to look at the compression ratio.
What sort of power can the RB25DE hack before it spits the dummy?
https://www.sau.com.au/forums/topic/12811-internals-strength/
I am not sure with specific in detail of the internal of RB25DE.
but internal is not same as turbo skylines RB25DET.
When I had my GTS-4, Internal was Strong and power chart(dyno) curves were near 45 degrees, no flawless (maybe bcuz of Access Blitz ECU).
I never had oil drop under the engine nor diff or any liquids, only liquids came out of car is Water from aircon.
and I tell you I was threshing my car, I mean threshed it! :(
but always serviced with top quality oils.
cheers
Joe
Well, as far as i can see, wacking a turbo onto the side of my 25DE engine, and running mild boost, say 4-6psi shoudlnt be all too harmful.
Yeh i thrash the daylights out of my car, go the synthetic oils !
Is the oil circulation the same, that would be an important issue.
factory turbo, cooler, intake and bov, exhaust manifold.
GTSLink ecu. Standard NA injectors.
an instant 30% more peak power and lots more pull especially midrange.
I'm actually about to get another 25t engine/box very soon. Thats definately the way to go i think if you guys are serious. More power more easily.
It will surely be interesting when i disect the N/A engine and see what damage, if there is any.
When you think about what it costs to buy all the parts and ecu etc to do the conversion, the same money will buy you a 25t engine/box/factory ecu no tuning etc required. Plus you could sell off some of your NA bits head etc - starts getting even cheaper.
I personally dont think the brakes need doing but if you can upgrade them cheaply go for it. Apparently the same brakes are still used on a neo 25t stagea.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
