Hey there guys,
I have an R33 GTS S2 standard ECU. Since I bought the car it's had an aftermarket (non-airbag) steering wheel on the car, though recently the battery went flat in the car and now the airbag light is flashing in my eyes and is rather annoying.
Does anyone know of a way to shut this down? It's obvious there is a way, seeing though for the past 8 months it wasn't flashing. Also, just out of curiousity, does the factory ecu have fuel maps and such that people refer to when discussing aftermarket ecu's and or do you think there is any programming I could have perhaps lost in my ecu since the battery has died, and if so is there any software available to see what is happening in there???
Any help or info would be great...
Cheers !!!
https://www.sau.com.au/forums/topic/128116-airbag-light/
:D
Hey there guys,
Cheers !!!
Thats an interesting problem you have there dude. you say you have a r33 gts s2 ecu? first off i would be getting my hands on nissans consult scan tool to pull some codes out of it and see what it is saying. considering the fact that it is now missing the return signal from the steering wheel mounted airbag unit will definately be the reason for the light. my first question would be why has the s/wheel been replaced with a
non airbage unit and how did they turn the light off? i know this isnt alot of help but i'd be a bit worried about because with the light on remember the passenger side airbag will NOT deploy in an accident and to be honest with out the seering wheel there i doubt whether it would go off even with the light off.
as for the ecu, yes it has fuel maps and there is a few resets u can do to ensure good idle such as a Keep Alive Memory relearn and an idle reset,
glenn
https://www.sau.com.au/forums/topic/128116-airbag-light/#findComment-2367721
I'm not sure how the airbag light was disabled... I bought the car with the aftermarket wheel fitted from an importer, so it was complienced with the steering wheel fitted. I have no idea how the setup was, though the light would come on when first starting the car (as you would expect, with the engine light etc) thought after 1 or 2 seconds of the car running, the light would disappear, it was as if they had trick the computer to thinking there air bar was there.
As for the ECU settings... you said there is something like a self learn proceedure? How do I initiate that and whats the story - is there a website or a topic in SAU that gives instuctions... the car is running fine atm, so should I have concerns in reseting the ECU ??? Has anyone done this - should I just let it be???
Cheers...
https://www.sau.com.au/forums/topic/128116-airbag-light/#findComment-2367735
do a search for
airbag
by user ylwgtr2
he posted up a way to clear the self diag. try this and you should speak with a nissan dealer about the problem, as it could be dangerous (ie: airbags may be disabled)
https://www.sau.com.au/forums/topic/128116-airbag-light/#findComment-2367852
Common issue when the airbag is disconnected from the power supply. To remove the light you need to reset the signal to the ECU, i think its via resetting the ECU. Talk to NISSAN about who has diag tools.
In the meantime your airbag doesnt work so drive safely
https://www.sau.com.au/forums/topic/128116-airbag-light/#findComment-2367882
Cheers...
i would dare say that the light was turned off with a resistor or a simulator placed into the wiring at the steering wheel connection to the airbag harness. i would say that with the new batery connected the voltage/resistance seen at the control unit has slipped outside of preset parameters. how and why i dont know....................... :wave:
https://www.sau.com.au/forums/topic/128116-airbag-light/#findComment-2367941
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
