brant, mongoose have keypads..
Its a tough question to ask which alarm is best. They all do the jobs in one way.
But then a pro will always know how to disarm it.
But i would look at mongoose m80 with kaypad. Heard they good alarms.
Then again someone else might not think so.
Why not try quicktrack?
Installers for brant and mongoose would have to be alan jon. Search sau if you want.
Hi guys, im in the process of installing a alarm system, i was going ahead with the quiktrak but now im thinking otherwise
what else is there on the market that is good? any with trackers? key pads? etc?
thanks!
Autowatch make a very nice keypad which is very reliable
  • 4 weeks later...
Yep, Autowatch are great. I have a 446lri, which was installed by Leon from www.securityinmotion.com.au. You can tell by the quality of his work that he is a pro. Try stealing my car.. Now the sensetivity is turned up a bit u cant brush past the car without gettin a nice reminter to not touch the painwork ;-)
ok, let me just point something out to you.
NO CAR IS UNSTEALABLE.
Your 1997 R33 Series 2 showing 60,XXX km, with pod filter and cat back 3" exhaust is no exeption. And the northern beaches area is definately not the place to be telling people what alarm you have in the car.
Got my point?
yup im 100% sure the m80 alarms can come fitted with kaypad. Ask alan jon. Im pretty sure he said he can install it with keypad.
Cheers
but not a mongoose item. the autowatch one posted earlier will fit anything.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
