Dont bother if stock boost. I'm running 10psi thorugh a r34 SMIC and it is fine. A FMIC at 10psi or less or even on the stock turbo is a bit of a showy thing rather than a performance gain.
Unless your on boost around a track for hours , then a FMIC might be worth it.
so u reckon the r33 smic is sufficient? or the r34 smic is a worthwhile upgrade on my r33. it gets up to 9psi on a cold night with pod and exhaust. i'm worried about the summer temps though. havent been there yet.
Edited by Munkyb0y
A GTT intercooler on a R33 GTS-T is a very good upgrade it is effecient for power levels up to 200rwkw.
my 2 cents
For those saying the power increase is due to less pressure drop id say you are correct but its not because more boost is generated. Boost is messured after the intercooler remember. Power can be gained on the same boost level because the air is cooler this is for 2 reasons
1. less pressure drop so the turbo doesnt have to work as hard to produce the same boost
2. The efficency of the intercooler (air cooling is better)
The colder the air the more oxygen it contains and the quicker it burns. Boost does make power but sometimes quality of air is better than quantity.
If you choose to run stock boost not much will be gained by installing a FMIC because the stock one is efficent at this level.
I was running 10psi with the stocker then upgraded to a hybrid FMIC, I gained heaps of power on the same boost
cheers
hey chopobo, u rekon u could post up a pic of front of the car and the engine bay, just wana c how they fit up, as im thinkn bout getting the same kit
I installed the gktech kit aswell and it seems to fit well. I'll post some pics this weekend. (Cutting back an S1 bar is TEDIOUS!!!!!)
does the GTT smic fit straight onto the r33? as i've been lead to believe?
YES.
It is a DIRECT bolt on.
Unbolt stocker, replace with the R34 one.
On the R32, one of the end tanks are on a different angle and it needs mods to fit that.
But for the r33 and stagea, it fits straight on.
PAUL - SK had stated previously that the R34 smic was used in his R32 with the rb20 at 220rwkw.
He did have some temps that he posted here.
have a search for a thread with R34 intercooler and SK in the search options from a few months ago.
here is a bick of the GTECH kit on my car. I replaced a 34GTT SMIC for this one.
I'm running 16psi though it an ran it up to ~280rwkw last week. It could go more but my injectors were maxing out. Runs fine, I see no problems with it at all. Although it was installed with a new turbo setup I get max boost at 3500 and it cains.
this is all with the plate in the front :) next weekend this will be moved
gk gk gk gk gk gk, not Gtech, gktech!! lol
Looks nice mate, do you have any engine bay pics?
Greg
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
