Dont bother if stock boost. I'm running 10psi thorugh a r34 SMIC and it is fine. A FMIC at 10psi or less or even on the stock turbo is a bit of a showy thing rather than a performance gain.
Unless your on boost around a track for hours , then a FMIC might be worth it.
so u reckon the r33 smic is sufficient? or the r34 smic is a worthwhile upgrade on my r33. it gets up to 9psi on a cold night with pod and exhaust. i'm worried about the summer temps though. havent been there yet.
Edited by Munkyb0y
A GTT intercooler on a R33 GTS-T is a very good upgrade it is effecient for power levels up to 200rwkw.
my 2 cents
For those saying the power increase is due to less pressure drop id say you are correct but its not because more boost is generated. Boost is messured after the intercooler remember. Power can be gained on the same boost level because the air is cooler this is for 2 reasons
1. less pressure drop so the turbo doesnt have to work as hard to produce the same boost
2. The efficency of the intercooler (air cooling is better)
The colder the air the more oxygen it contains and the quicker it burns. Boost does make power but sometimes quality of air is better than quantity.
If you choose to run stock boost not much will be gained by installing a FMIC because the stock one is efficent at this level.
I was running 10psi with the stocker then upgraded to a hybrid FMIC, I gained heaps of power on the same boost
cheers
hey chopobo, u rekon u could post up a pic of front of the car and the engine bay, just wana c how they fit up, as im thinkn bout getting the same kit
I installed the gktech kit aswell and it seems to fit well. I'll post some pics this weekend. (Cutting back an S1 bar is TEDIOUS!!!!!)
does the GTT smic fit straight onto the r33? as i've been lead to believe?
YES.
It is a DIRECT bolt on.
Unbolt stocker, replace with the R34 one.
On the R32, one of the end tanks are on a different angle and it needs mods to fit that.
But for the r33 and stagea, it fits straight on.
PAUL - SK had stated previously that the R34 smic was used in his R32 with the rb20 at 220rwkw.
He did have some temps that he posted here.
have a search for a thread with R34 intercooler and SK in the search options from a few months ago.
here is a bick of the GTECH kit on my car. I replaced a 34GTT SMIC for this one.
I'm running 16psi though it an ran it up to ~280rwkw last week. It could go more but my injectors were maxing out. Runs fine, I see no problems with it at all. Although it was installed with a new turbo setup I get max boost at 3500 and it cains.
this is all with the plate in the front :) next weekend this will be moved
gk gk gk gk gk gk, not Gtech, gktech!! lol
Looks nice mate, do you have any engine bay pics?
Greg
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
