hi guys,
just got my car back after it got tuned.
we got 220.3rwkw. i just wanna know if this sounds right?
mods are as follows -
fmic
13-14psi thru gfb boost controller
plazamaman plenum
ces dump
pfc.
walboro fuel pump
thanks for your opinions -
glenn
https://www.sau.com.au/forums/topic/128152-just-off-the-dyno/
  • Replies 63
14 psi is a lot for a standard turbo.. too much for mine, for instance
yeah still the standard turbo, injectors and fuel pressure. car was properly strapped and in shoot_6f with correct dyno cell info entered
its quiet possible, i got 220rwkw with a stock turbo on mine, i had the following:
stock turbo
custom exhaust manifold
turbo back 3" exhaust (split dump pipe)
Blitz POD
FMIC
SAFC II
electronic boost controller
we pushed it to just over 1bar on the dyno, but for regular driving i kept it on 12psi (for safety reasons)..
you can see the spiking due to the cheap hybrid electronic boost controller i had at the time, with the new turbosmart valve it actually holds boost a lot better..
Edited by MKDR33
Dyno charts don't mean squat. Get a group of cars, at the same dyno, on the same day, then you can compair mods to power.
220 sounds really high for a stock turbo. At 13psi i would expect 180-200rwkw max. There is no rule for max boost on stock turbo, it is basically like playing "Russian roullette". Some turbos can live on 15psi for years without any problem, others will blow on 10psi after a couple of months. Your turbo is more likely to blow at anything over 12psi, but mine lasted for years at 13psi and still was in good condition when i sold it to upgrade to a bigger turbo.
I don't get it, do people like wishing their turbo hangs together all the time? Is the thrill of knowing your turbo could let go at any time and possibly damage your engine that good? Maybe this sort of mentality explains a lot of blown engines/parts? I think i might be onto something here..
Edited by govich
yeah...its kind of like mastabating with a cheese grater :happy:
hi guys,
here is the dyno run as requested. i apologise it is only the 219.7rwkw run that we printed off, so i guess i dont have 220kw but close enough. I am not really expecting the turbo to hang on for that long but there is plenty of fuel there so we'll see. If this little exercise has only done one thing thou, it has definatley shown me the advantages of working with your selected tuner to achieve the results you desire.
the chiptorque crew spent a fair share of their free time to get that done for me, and so i must recommend them to all u guys as a fantastic business that will get you the results you want.
cheers
glenn
Both dyno sheets posted that have made 220rwkw odd are not holding that 14psi or whatever to peak power...
So... Peak power of 219rwkw was made on roughly 12.6psi and the other dude that made 220rwkw... That was on a shade over 10psi.
So yes.. hrmmmmm, either way its a power figure... Who cares, A real 220rwkw I'd expect a high 12 sec pass with a good driver.
200rwkw.. A low 13. Once again with a decent driver who can drive.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
