Nissan Pulsar N16 MY2004,
Manual 1.8 Litre
Advertising on behalf of my mate, whom is the owner of the car.
Nissan Pulsar N16 MY2004 ST model
5 speed manual
approx 55,000km, full Nissan service history.
Still under factory 12 months warranty.
Reg expires October 2006. RWC will be provided.
Very fuel efficient. 50 litre full tank will get you approx. 700-750km
Has lowered King Springs, but isn't really that low from stock. Will provide factory springs aswell (if you intend to swap over later on).
Dark tinted windows.
Pioneer mp3 head unit, Pioneer front splits, Pioneer 6x9, Sony Xplod amplifier.
Always garaged.
asking $14,000 PRICE DROP $13,700
Epping VIC 3076
Contact John on 0413 923 723
at the moment only have one photo, but will get more photos soon.
Also advertised on CarSales.com.au
http://carsales.com.au/pls/carsales/!c...p;cs_trans_id=2
Asking Price: $13,700 OR NEAREST OFFER
Edited by nohope
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
