all parts for sale are for R32 GTR
pair of std turbos one blown $100 ono
2x dump pipes $30
std fuel rail and reg $50
std cam gears $40
std cam gear cover (rb26) $30
twin turbo pipe $50
r32 gtr front brakes(rotors,calipers,pads) SOLD
nismo front braided brake lines $120 ono
bendix ultimate brake pads $100 Ono
HKS F con Pro v vers 3.2 and harness for gtr $1500 ono
radiator new condition $270 ono
All prices are neg
pm me for sales or post here
cheers
brendon
Edited by NIZ-26T
https://www.sau.com.au/forums/topic/128157-r32-gtr-parts-forsale/
Can you please send pics of the braided brake lines to [email protected]
Are they from the chassis to the calliper?
Thanks...
edit: and brakes pics too please...
what condition of rotors and pads?
  • 3 weeks later...
