Got bored with nothing to do today so I decided to do some polishing work to "further" dress up that engine bay :) Can never have enough bling under there to show the cops ~
Anyways, decided to finish off the half hearted job I did on the BOV pipe so I removed it and got to work... took the following steps:
1) Removed all the unsightly cast marks that do nothing but make it look ugly
2) Removed any unecessary chunks of metal used for mounting (only the ones not used)
3) Prepped the whole pipe's surface for polishing
4) Polished :happy:
5) Got very dirty :no::);)
Anyways, whole process took about 3 hours and the result came up really good :) Almost looks like a custom piece of metal was fabricated. I only did the bits that you can see from opening the bonnet and walking around it; didn't bother with the underneath side.
Here are some pics; comparision with the stock un-polished pipe that I had lying around the shop:
post-19974-1154261680.jpgpost-19974-1154261720.jpgpost-19974-1154261706.jpgpost-19974-1154261729.jpg
But then I got even more bored and decided to polish the standard BOV and fit that in atmo setup; getting sick of the flutter sound :) This is what I came up with...
Fitted it and hoped for the best... didn't really like the sound so I took it off and drilled 4 whistle holes into the chamber pipe... re-fitted and went for another drive; perfect!!! Nice and subtle pssshhhtt; can hardly hear it and with a bit of throttle control; can actually have it on/off :P
Anyways; just thought I'd tell my story for the day...
If anyone wants more info; just PM me :)
https://www.sau.com.au/forums/topic/128210-got-bored-did-some-polishing/
  • Replies 48
Thanks mate... actually was my second polishing job of the day; first one was for one of our customers... he did it so it looked like a continuation of his FMIC pipe into the throttle body instead of looking real ugly from the top half upwards.
Started off using an angle grinder to get rid of any of the stuff I didn't want on the pipe; then used various types of discs to get it all smooth and ready for polishing.
Polishing was done on a bench grinder with different types of wheels and compounds... finished it off with a kerosene bath to remove any polish left (not good for engine) and voila!
Nice... that would've taken ages!!!
haha yer its not a quick process, ive had soo many mates come and see it and say oh ill do my rocker covers only to see them give up half way through and leave em dull as hell. should see how damn black my face and arms are after spending hours in front of the buffer.
worst part is they are spotless until u install them and then touch them with oil/greasy hands then it marks em and they require a rebuff :)
definately worth it in the end though, ive done, rocker covers, coil cover, alternator, intercooler, timing cover, intercooler piping, plenum, throttle bodies, throttle cable setup and anything else thats made of ally in the engine bay :)
thats actually my old cars engine bay its now got a single turbo so i had to put all those twin turbo pipes away for good after all that effort. those intake pipes are hpc coated not polished thats why they aint shiny.
so u gonna do your rocker covers and stuff now or u think its too much stuffing around???
Edited by CruiseLiner
who that looks great... i should polish tha standard one i got before i put it in the enginebay so it goes with everything else...
a front facing plenum looks awesome too. makes the engine bay look way cleaner without intercooler piping snaking its way everywhere...
My rocker covers are already done... most of the metal in the engine bay is done actually; only have the intake plenum and throttle body to be done and that's about all...
I've even going to the extent of polishing up all the brass bits (all the brackets etc) to make it all match up and shiny!
You are right, it does take ages - I guess we're lucky because we have all the tools etc from doing it as part of the business.
Did you use all different compounds to get that sort of a finish? I find that the compounds reduce the time involved by heaps...
Question: are your turbo comp covers all polished too :)
and how did you go about removing those cast marks or chuncks?
Guess if youre going too that much trouble to make it all nice and shiny wouldnt it be better while its in bits too get them anodised (assuming theyre an aluminium/aluminium alloy?) and keep corrosion off.
Never have too paint or polish them again either!
sounds like u done most of it then :) no my turbo comp cover isnt done (wasnt done on the low mount twins either), my hks turbo is a funny rough finish and it says hks t04z on the front and polishing around letters is a pain and half done jobs look worse than not doing it at all.
this is the new engine bay (sorry the photo was taken with shockin light so its hard to see)
i remove the rough casting marks with a round flapper sanding wheels on the drill, and sometimes a grinder with a flat sanding disk if its really rough. then use 240 grit sand paper, then 400 grit, then 600, and then 1200, then onto a hard buffing wheel, then a medium buffing wheel and then the polishing wheel (always using same compound on every step, white stuff, unsure of the name).
cheers
The anodized look doesn't really do it for me; too "dull" IMO. Another factor is that it costs too much to do.
Keeping the parts polished/shiny is easy - once every month just wipe everything down with some kerosene and it's like new!
You should look into the different compounds available for polishing wheels; you'll find it'll cut the times down and give you a better finish.
Also; since you're polishing it on the grinder - there's not really much need for the sand paper; it'll all get smooth once it's polished.
But I like your work; it's very very nice!
I'll take some photos of my engine bay and I'll post it up too :)
can u get the names of the different types u use for different stages? ill be doing my other rb26/30 engine in the near future so any tips to shortcut things is a bonus :)
CruiseLiner: I'll talk to my business partner who purchases all our polishing supplies. I'll PM you if he tells me; he's pretty anal about the stuff - I've just picked it up from watching him do it all the time.
Munna1: Totally agree :)
Here are some really crap photos of some work we did for a R32GTR just before the customer sold it... I think the goal was to increase the "value" of the car somewhat, and/or make it so it's that bit more attractive?
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 馃構 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
