depending on what you need the motor for, the cometic metal gaskets are really a good option and usually cheaper than the std nissan composite gaskets
i got mine retail for $330 about a year ago, in sydney.. cant say any local people in Melb but this should give you an idea
lots of people use them and reccomend them.
