I'm with Shannons and have every modification covered, they even have the brands and model numbers of all modications including my rims, computer, coilovers, pod etc....
Shannon's are great with modifications. I asked them about if the modification is illegal will i be covered in the case of an accident and the answer i got was...
'You will definately be covered provided it wasn't that specific modification that caused the accident.'
And when they say caused they mean 100% at fault for the accident, there is no way they would try to prove or can prove that one modification could be blammed for an accident, as there is usually a certain amount of driver error involved as well.
yeah I'm with Just Cars for all my cars.
When smashed my r33 I even negotiated a higher agreed value over the phone after the fact based on mods I had not called them about cos they were new...I was really happy with that. Although they ended up fixing it and fixed it good incl. a diff. front bar etc and some other choice changes I got them to do for free - by them I mean the panel guys.
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
