I had a Brant one with a 1-2-3-4 pad worked OK But had some problems. I would put a couple of kill switchs in out of sight
BTW if thats your 31 in ur avatar looks schmick :pirate:
Edited by Flipmo
BTW if thats your 31 in ur avatar looks schmick :D
Autowatch have a nice keypad which is very reliable
Get the brant nemesis.. Search for Alan Jong.. he installs them.. around $1000..
it's a 6-point - but really.. 3-point + 3-point keypad..
Works well.. haven't really had any issues, only problem is the range of the receiver to unlock/lock the car.. about 2m..
the one posted in the NS area is an autowatch item. leon (SIM) sells them in sydney I do them in brissy.
they can be added to most autowatch alarms as an add on.
forget brant- no longer worth the effort.
Out of interest Chris why would you say that? regarding forget brant?
One of the reasons for myself getting a brant alarm was that I didn't want someone stealing my keys and also the visual deterrant the keypad has..
Realistically if someone wants to steal it they will.. and it's fully insured.. but I guess anything you can do to protect your car helps..
I've been really happily with it.. only issue I have is the distance that the remote works.. it's terrible!!..
Have a look around see what you like.. if you were in qld.. def go and see Chris.. however I don't know about vic..
Edited by Links
$150 fitted
I would be worried about the numbers wearing off after time which may suggest the pin. Farnell sell a vandall proof keypad with the numbers etched into the buttons which are metal. The whole thing is a metal unit making it very difficult to open up.
no my 5 digit pin only uses 3 buttons, $100, or $150 fitted i'm not worried about numers if they starteed jsut scrape them off or somthing. Oh thats not my car btw, i mounted mine in teh center consle so i dont' even look at the numbers when i type them in.
I have to add you dont' get to chose the pin, it comes with one and its' actully a 5 digit pin.
Edited by Michael_1882
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
