1991 Nissan Silvia Turbo
Bought in 2000, car is meticulously maintained and totally modified here in Melbourne, all kilometers are GENUINE.
A perfectionist owner, this car is always treated to the best of parts and service and always run on the best fuel. Serviced every 3-5000ks.
Modifications include:
Engine/Drivetrain-
-sr20det engine conversion, engine has 100k, car has 170k, car was originally imported on 110k.
-t28 ball bearing turbo
-custom metal air intake pipe
-front mount intercooler with custom piping
-blitz air filter w/ cold air intake setup
-extreme heavy duty 5 puk button clutch, machined fly wheel
-screamer pipe off turbo
-full 3 inch exhaust with gtr cat converter
-4.3' diff gear ratio
-blitz dual stage electronic boost controller
-refurbished alternator
-new radiator
-bosch 904 external fuel pump
Interior-
-Type X door trim and dash insert
-detailed interior highlight
-apexi turbo timer
-jvc mp3 head unit
-pioneer door speakers
-autometer boost and volts gauges in custom a pillar
-chrome pedals
-momo steering wheel with original momo boss kit
-keyless entry, 6point alarm with dual remotes.
Exterior/Ride-
-respray in factory colours, champegne silver over grey
-j's rare square heaadlights,
-17inch rims powder coated white, new rubber
-lowered springs
-koni adjustable dampening shockers
-front and rear strut braces
Personal comments:
Owner is extremely fussy and the car has only seen the best. Driven almost daily, you will not find a cleaner, neater, quicker example of an s13, always tidy, reliable and good on fuel!
Car has run 12.48 at 109.7mph (slicks), currently making 180rwkw.
All of receipts for work, labour and parts that have gone into the car are available, as well as many many extra/stock parts.
A fantastic car to drive, i would love to see it go to someone who respects it as much as I have.
Please call 0400 20 50 25 or email [email protected] for further information. Price IS negotiable. Will remove parts to lower price.
Will sell for 13,350 as it sits, proven 12 second car with all the trimmings above.
Or will sell for 12,800 without the 17s, deck and steeringwheel.
Remember, negotiation is welcome, and also am considering swaps+ cash adjustments, but not down the path of performance again, would prefer a 4 door, 4 cyl if possible, open to is200s, accord euros, mazda 3s, pug206gti, corolla sportivo, etc, will consider anything so all invitations welcome.
Thanks for reading!
Edited by xdrift
damn i left that out didnt i!!
yeah bud, sr20det.
sorry i should mention car has 170,000kays, it was imported with 110,000.
the car has had the sr20det engine conversion, and turbo engine has 100,000 kilometres give or take 100.
also retaining all paperwork for the car, importing papers, parts receipts, work receipts, speeding fines, past rego stickers etc.
im pretty well kept.
thanks for the compliment too!
Edited by xdrift
are you serious?
im not so sure about swaps that way.. as i need teh cash for an intended overseas trip.
if you are keen tho.. hit me up and we can chat and check out eachothers cars. like gay men. 0400 20 50 25.
Edited by xdrift
  • 2 months later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
