I've done a search and found a few answers, but not all. Apologies if these questions have already been answered but keep in mind that there were a lot more to begin with that I would have also asked if I didn't search :P
Ok, it seems the general consensus is that once you hit around 220rwkw, you'll need to upgrade your fuel pump, and possibly the regulator. I am looking at getting a Bosch 044 for this reason.
The most important question I need to ask is - What is the part number? The reason I ask is because I have a friend who *may* be able to get me wholesale prices, because his company deals with Bosch. But since it's mostly NOT for car stuff (mostly power tools and other electrics), he'll need a part number rather than just ordering a "Bosch 044 fuel pump".
My next question is would I also need to upgrade my regulator at the same time? If so, what should I be looking at getting, and roughly how much should I be spending? I don't care about brand names, as long as it does the job I'll be happy with a cheapie (but preferably new) item.
Oh, and lastly - are these things relatively easy to fit yourself? Do they bolt straight up or do they need an adaptor of sorts? Do I need to pull the fuel tank out to fit everything?
https://www.sau.com.au/forums/topic/12826-fuel-pump-and-regulator/
Despite I have one, I have no idea what the part# is.
You shouldn't necessarily need to replace / upgrade the pressure reg.
email the boys at Zoom ([email protected]) and ask them which issue had the article about installing the upgraded pump - but its not a simple pull-one-out-put-one-in upgrade though.
Good Q's Jimmy coz im up to the same type of area with my mods.
203rwkw and im thinking that a Rising Rate Fuel Regulator ~$190 should help fix up my leaning out problem at top end on 12psi. Even if it doesn't it'll be needed anyway sometime throughout this year.
The Rising Rate Fuel Regulator needs to be tuned I believe ?
Lemme know if you get any prices Jimmy I might be in for a group buy :P
Ben, where are you getting the rising rate regulator from? Where does it actually go? At the tank or the fuel rail or somewhere in between?
Blind_Elk, I've emailed them and am waiting for a response. Off-hand do you know roughly what's involved? Like, do I have to cut a section out of the tank, make an adapter, drill new mounting holes, etc? How much would a performance shop charge to do all this for me? I'm pretty handy with a spanner, but working around fuel makes me nervous :P
Thanks for that info Browny, but after reading the thread I just have more questions :P
The 044 seems to be too big for my application, if the cheaper 984 can flow up to 600hp. Even 600hp is way beyond the scope of anything I want to do with the car in the near future, so should I be looking at getting the 984 instead and save myself $100?
Are all these pumps pretty much the same size and shape, or do some require more or less work to fit and get working properly?
Edit: 'nother question - Am I getting an internal or external pump here?
I did a search on google i think for aussie websites and they seem to be around the $195-$215 price for a brand new unit. I have absolutely no idea where they go or anything like that
:bahaha:
I just got a response from the guys at Zoom, they told me the fuel pump article is in issue 36, and that it's no longer available :P Can someone that has that issue please scan the article for all us fuel pump upgraders? :P
I can only do it in 'hard-copy' ie fax the pages to you. Do you have a fax# (pm me if you do). (And it won't be until tomorrow.)
Hi guys, fuel pump info as we know it.
GTST pump is 135 litres per hour and supports 300 bhp at standard pressure
GTR pump is 190 litres per hour and supports 420 bhp at standard pressure
Bosch 910 pump is 200 litres per hour and supports 450 bhp at 73.5 PSI 0 580 254 910
Bosch 975 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI 0 580 254 975
Bosch 984 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI 0 580 254 984
Bosch 044 pump is 330 litres per hour and supports 730 bhp at 73.5 PSI 0 580 254 044
Bosch 040 pump is 235 litres per hour and supports 520 bhp at 73.5 PSI 0 580 254 040
We use one GTR pump mounted in tank up to 400 bhp and for engine over 600 bhp we use twin GTR pumps with a surge tank and a GTST lift pump in tank.
Hope that helps
Question regarding the wiring up of these pumps. As I understand it at present, the factory pump doesn't pump out at full capacity all the time, it waits until you open the throttle up before giving it a full earth. There's another thread here that talks about giving the factory pump a constant earth all the time to help with stalling problems at idle.
Should the bigger Bosch pumps be hooked up in the same way or should we hardwire them to a constant earth? I'm mostly concerned with burning the pump out too early by running it constantly at full capacity. But if that's what they were designed to do (unlike the factory pump it seems) then that's what I'll do ;)
Edit: Oh yeah, thanks Sydneykid! I didn't even notice you had the part numbers in there at first, it kind of blended in at the end :D
Btw, since the 984 is good for up to 500hp, I think I'll go with that because my turbo only flows up to 450hp anyway. Unless the bigger 044 allows the stock injectors to flow a little better? If so I'll spend the extra $100 now so I can delay or put off indefinitely my injector upgrade.
Sydneykid, help!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
