Hey guys,
I have an R33 GTSt. Today while driving I was putting my foot down bit, the car just started to come on boost and take off, when the car made a popping noise and just died there. It sounded to me a bit like a cooler pipe blowing off, but my car is running an EMS and will still run with a popped off cooler pipe (checked them anyway and they are all fine).
After a couple of times trying to re-start the car, it would start and idle, but if you touched the thottle at all it would just die.
When going to start the car I noticed I could not hear the fuel pump (which is still the factrory pump).
I pulled the pump out of the tank and wired it so I could check it on the battery, and the pump still works.
With a test light, I checked the power to the pump, and there is nothing. I have checked the fuse (the one in the boot next to the battery) and it is fine and getting power.
I am at a loss at this stage. Is there a relay for the fuel pump? If so which one is it so I can check it.
Could it be something else?
Any suggestions would be great.
Jeff.
https://www.sau.com.au/forums/topic/128289-fuel-pump-problem/
there is a fuse and relay in the boot next to the battery for the fuel system
ther relay is switched from the ECCS relay in the passenger kick panel..
i had a similar issues in my car after i used the std wiring as a trigger for a 044 pump ...
had to rewire a switch manually to get me going and havent gone back to find the issue that caused it ;)
Edited by Craved
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
