Hey guys,
I have an R33 GTSt. Today while driving I was putting my foot down bit, the car just started to come on boost and take off, when the car made a popping noise and just died there. It sounded to me a bit like a cooler pipe blowing off, but my car is running an EMS and will still run with a popped off cooler pipe (checked them anyway and they are all fine).
After a couple of times trying to re-start the car, it would start and idle, but if you touched the thottle at all it would just die.
When going to start the car I noticed I could not hear the fuel pump (which is still the factrory pump).
I pulled the pump out of the tank and wired it so I could check it on the battery, and the pump still works.
With a test light, I checked the power to the pump, and there is nothing. I have checked the fuse (the one in the boot next to the battery) and it is fine and getting power.
I am at a loss at this stage. Is there a relay for the fuel pump? If so which one is it so I can check it.
Could it be something else?
Any suggestions would be great.
Jeff.
https://www.sau.com.au/forums/topic/128289-fuel-pump-problem/
there is a fuse and relay in the boot next to the battery for the fuel system
ther relay is switched from the ECCS relay in the passenger kick panel..
i had a similar issues in my car after i used the std wiring as a trigger for a 044 pump ...
had to rewire a switch manually to get me going and havent gone back to find the issue that caused it ;)
Edited by Craved
