Thanks Scott - I have heard of these guys - might pop in there tomorrow to see what they are like - I don't know anyone who has used them.
Are they a quality shop ? i don't mind paying for quality
Cheers,
Can you point me to one for a 20B Cosmo Richard ? If so, I would be inclined to get that.
Went to Cromer Exhaust today - Full system - dump, metal cat, resonator, 2 mufflers (one each side) Full stainless, Mandrel bends, 3" - $1600
Cheers,
Cheers,
B-Man, please reconsider what you posted above. I will PM you details
I would highly suggest using Cortis in brookvale, they are good and have done work on Dal's Cosmo!
Edited by carlo
Speak to Gary at Northshore Performance Mufflers in Hornsby. The guy is an absolute champion, does great custom work at a reasonable price. He's helped me and all my mates on our cars and we've been very satisfied with his work.
agreed with Pat :P
My old VT LS1 exhaust system was done with Gary at northshore.
Awesome power increase and absolute ball tearing sound!!!!
was impressed and a few other friends have gone there too.
He fitted my 2nd hand cat back on my 33 - did a good job too.
:D
Cheers,
FUJITSUBO Legalis R for JCESE Cosmo (20B)
http://www.fujitsubo.co.jp/search/prod-v.p...368&cnamID=
Free delivery to the Northside just for you B Man :P
Well - the car is booked in with the boys at Brookvale Mufflers.
Andrew & Jamie there are top shelf guys - Stan you were right mate - they are good.
Jamie took me through EXACTLY what he will be doing and why ! Had the car on the hoist to double check everything. (the others just quoted and didn't even look to see what it needed).
Others told me 3-4 days for install - Jamie will have it all done in 1 day.
Price is very very good too !
So I am happy - Booked in next tuesday, can't wait !
Cheers all !
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
